Debadge or Plasti Dip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 13tacoma4x4, Dec 4, 2013.
  1. Dec 5, 2013 at 1:24 PM
    Jhunter
    Jhunter Well-Known Member
    Atlanta
    Black '14 TRD DCSB
    Just getting started
    Just so I'm clear, some of you are leaving the emblems on the truck and then taping off a large section and doing the Plastidip process on the vehicle?
  2. Dec 5, 2013 at 1:27 PM
    Aw9d
    Aw9d That one guy
    Paint FTW.. Plasti dip is nice but you get a better look with paint IMO.
    Removal is easy.> Blow dryer on the badges for a few minutes,, fishing line to cut them off. It takes more time to retape them than anything else.
  3. Dec 5, 2013 at 1:36 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Correct...
    I just taped off around the emblems leaving about a inch on the outside of the emblem.
  4. Dec 5, 2013 at 1:42 PM
    Jhunter
    Atlanta
    Black '14 TRD DCSB
    Turner - Do you have a photo of what it looked like when you were done?
    Sorry for all the questions. I've spent the last 10 years riding dirt bikes and this truck has become a new hobby...
  5. Dec 5, 2013 at 1:48 PM
    RearViewMirror
    Craig Christ
    Only the one's I posted earlier. The entire area will be painted. I took the end of a needle and just peeled up one corner and pulled it off the paint. It will stay on the emblem as you pull it off. I think there are some write-ups on here somewhere but really it is very easy. Just take your time doing it and it will turn out fine. Nice thing about it is if you mess up it peels right off so you can try again.
    If you do decide to do it my tip would be to turn the spray can up-side-down and clear the paint out of the nozzle between coats so you will get a even spray pattern each coat.
  6. Dec 5, 2013 at 1:53 PM
    Jhunter
    Atlanta
    Black '14 TRD DCSB
    Now it makes more sense. I didn't understand that part about pealing off the extra plastidip from the vehicle's paint. At first, I thought that you were leaving a square background around the emblem. So the dip peals off the paint but sticks to the emblem, cool...
  7. Dec 5, 2013 at 1:57 PM
    RearViewMirror
    Craig Christ
    Yup...
    On the last coat I let it set for about 10 mins. You want it to still be a little "tacky" so it will peel off easy and stick to the emblem. You can use a x-acto knife if you have any that is wanting to pull off the emblem while you are removing it. I didn't have that trouble though and you probably won't either.
  8. Dec 5, 2013 at 2:51 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Front emblem, grill and lower valance are dipped.
    GrillampValanceBlack-Installed_zps3893c5_142cb560c7e69d513301fa1acf1e1ad17e71ba33.jpg
  9. Jan 5, 2014 at 12:23 PM
    johngreen92
    johngreen92 Member
    Lenore WV
    06 black tacoma
    camo emblems
    i just camo my emblems..
  10. Jan 5, 2014 at 1:40 PM
    RearViewMirror
    Craig Christ
    Not my style but I am curious on how you did it?
  11. Jan 5, 2014 at 3:51 PM
    johngreen92
    johngreen92 Member
    Lenore WV
    06 black tacoma
    camo emblems
    Realtree nonmarking gun tape.
    Razor blade.
    Toothpick.(to push down around the edges real good)
    Hair dryer.
    I just cut the tape around all the letters, then heated it up so its easy to push in all the edges.
  12. Jan 5, 2014 at 3:54 PM
    dxpsman
    dxpsman Well-Known Member
    Brandon
    Oceanside, CA
    14 TRD Sport PreRunner
    AFE MACH Force-Xp 3" Cat-Back Stainless Steel Exhaust System w/Black Tips, Complete OME 3" lift, debadged, Body Armor 4x4 side steps.
    Initially, I dipped my badges. Next day, I de-badged and kept the front dipped. Much happier with the badges gone.
  13. Jan 5, 2014 at 5:05 PM
    RearViewMirror
    Craig Christ
    Well it looks like you did a hell of a good job! Impressed :thumbsup:
  14. Jan 5, 2014 at 5:14 PM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    You can order Pre-Runner badges in black from your dealer -- I found a savvy parts guy and he did it for me. I chose not to replace the Toyota badges and sprayed the front emblem black. I also de-decaled the truck -- TRD Off-Road -- I like the overall look.
    There are several pics in the link to my page below.
  15. Jan 5, 2014 at 5:27 PM
    #35
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    TOYOTA TACOMA PreRunner V6 made the tailgate look too busy for my taste. I debadged and the did a simple rebadge.
  16. Jan 5, 2014 at 5:33 PM
    #36
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    dipped mine including the rear bumper :)
  17. Jan 5, 2014 at 6:22 PM
    #37
    johngreen92
    johngreen92 Member
    Lenore WV
    06 black tacoma
    camo emblems
    Thanks man it took a lot of time...I was going to black it out but i have realtree camo seat cover and floor mats and stuff on the inside...so i decided that i would try and see... its lasted through a few pressure washes..
    :mudding:
  18. Feb 9, 2014 at 9:50 AM
    #38
    drewp
    drewp Well-Known Member
    south Jersey
    '14 Sport/DCLB
    Re: the plasti-dipping of the badges. I understand the masking off part...then peeling. I guess you should do the peel off of the body after each coat? And you don't have to go around the letters/etc. w/ a blade to seperate from the plasti on the body? I would think that the whole thing would peel off as one "sheet" if you don't cut around the letters, etc. I just decided yesterday that I want to do this to my new Magnetic grey metal. truck.
  19. Feb 9, 2014 at 10:40 AM
    #39
    RearViewMirror
    Craig Christ
    Peel it off the paint on the last coat. I used the "dull" end of a needle to start at one corner. When you peel it off it should stay on the letters. No razor or cutting required.
  20. Feb 9, 2014 at 2:35 PM
    #40
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    Painted w/Krylon Fusion and Rebadged :D
