Debadge/Rebadge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverStreak05, Mar 6, 2010.
  1. Mar 6, 2010 at 3:06 PM
    SilverStreak05
    SilverStreak05 [OP] Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    I decided to debadge my truck this afternoon. I know it's been covered multiple times before, but most of the threads I've seen here on TW are for newer trucks. Mine's a 2005, so I was a little worried about paint fade and having a ghost image left over. I got all the badges off, peeled as much as the old adhesive off as I could with my fingers, then hit the rest with goo-gone. Took a little work, but I was able to get everything clean, and as far as I can tell there's no ghosting. I took a few pics after I was done. It's kinda overcast out so the lighting isn't great, but whatever. I'll be painting the tacoma emblems black tonight and then re-install tomorrow. Will definitely be doing the fronts, but I'm not sure about the tailgate. I'm kinda liking the clean look of it empty. Anyway, here's the pics :D
  2. Mar 6, 2010 at 3:38 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    clean look in the back looks good. What did you used to take them off the truck? I want to this mod also. Thanks!
  3. Mar 6, 2010 at 3:44 PM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    What did you use to take them off? I had a hell of a time, I ended up only doing the tailgate, cut tacoma into "taco" and painted it black. Post pics after the re-install, i have a feeling i'll be inspired to do the rest. ;)
  4. Mar 6, 2010 at 4:27 PM
    SilverStreak05
    NorCal
    I heated them up with a hairdryer then used some fishing line and sawed back and forth behind the emblems. I'm not even sure heating them up helped any, but I guess it can't hurt it either. I'll post up some pics tomorrow after I get the painted badges back on.
