Debadging & tailgate wrapping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fenrisulfr, Apr 5, 2011.
  1. Apr 5, 2011 at 10:06 AM
    Fenrisulfr
    Fenrisulfr [OP] Well-Known Member
    SW-VA
    Tundra w/ TRD 5,7L V8 4x4
  2. Apr 5, 2011 at 10:07 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
  3. Apr 5, 2011 at 10:08 AM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    The best thing for removing an emblem is fishing line and a hair dryer... No screwdrivers.
  4. Apr 5, 2011 at 10:08 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i wouldnt try the screw driver...i used some fishing line and whatever adhesive is still left, remove with goo-gone
  5. Apr 5, 2011 at 10:09 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    Yeah stay far away from the screwdriver. Chipping the paint is probably going to happen.
    Pickup some fishing line, and use it in a saw like motion behind the badge. It's only held on with foam tape.
    Edit: You guys beat me to it.
  6. Apr 5, 2011 at 10:10 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i used fishing line to remove my badges, i sprayed a little bug and tar remover on the badges 1st to act as a lube, worked great
  7. Apr 5, 2011 at 10:12 AM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    :eek: Goo-gone is coming NO WHERE NEAR MY PAINT! You may think you wash it off, but that is some corrosive stuff. Look at how quickly it breaks down that annoying adhesive...
    Just dental floss or fishing line (although I think dental floss is softer, no risk of weird scratching) and a hair dryer. Work that adhesive off with your fingers. Avoid chemicals as much as possible.
  8. Apr 5, 2011 at 10:15 AM
    Fenrisulfr
    SW-VA
    Would acetone harm the paint?
  9. Apr 5, 2011 at 10:17 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Stay away from the screwdriver.
  10. Apr 5, 2011 at 10:54 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Acetone is the key ingredient in goof off/goo-gone. I would advise against it.
  11. Apr 5, 2011 at 10:55 AM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
    Goo Gone hasn't done anything to my paint.. :confused:
  12. Apr 5, 2011 at 10:58 AM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  13. Apr 5, 2011 at 11:07 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I'm not saying it's going to take the paint off. It's just not a chemical you want hanging out on your paint. As long as you thoroughly clean it afterwards and wax it prior to putting on any new decals (if you're going to do what the first link in the OP does), I would imagine you'll be fine. Just giving my opinion and telling you I wouldn't do it.
  14. Apr 5, 2011 at 2:49 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i used bug and tar remover to get the left over adhesive off of mine....worked great. washed it and waxed the area afterward. didnt have any trouble. i also used the fishin line when the truck had been out in the sun for a while in the summer . didnt even need a hair dryer.
  15. Apr 5, 2011 at 2:52 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    If you're going to go that route, why mess around. I say use a chisel...
    :eek:
    seriously... no screwdrivers!!!
  16. Apr 5, 2011 at 2:54 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    ususually, oil works. pam, etc.
  17. Apr 5, 2011 at 2:54 PM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    ^^ Agreed
  18. Apr 5, 2011 at 2:56 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    The spot where my badges where looks exactly the same right now as the res of the truck...goo gone is good.
  19. Apr 5, 2011 at 2:57 PM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    If it says on the side of it "safe for automotive paint" I will agree with you. Until then, I'll find other methods and recommend others do the same. Automotive paint, clear coat, wax are all a completely new game compared to household uses that most of these products are designed for.
  20. Jun 12, 2011 at 3:42 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    Out of all the mods I've read on here for my 1 month old truck I didn't figure I'd need any help with this one. Wrong! Used a can off Goof-Off and my finger nail to remove the dealer badge....and a spot of clear coat....and paint. I'm still steaming over this as it just happened 10 minutes ago. So multiple lessons here. Read the forums for ANY and all mods no matter how simple they are and don't use acetone based solvents on your truck. Time to cover up my dumb move with a sticker or something...:facepalm:
