debating 4 or 6 inch lift
Discussion in 'Suspension' started by tacomanyo, Dec 4, 2021.
  1. Dec 4, 2021 at 3:09 PM
    tacomanyo
    tacomanyo [OP] Member
    6 inch thing is cut
    i've heard 6 inchers have stability issues, the BDS 6" coilover kit looks real nice. Cant find a comparable 4 inch lift like it. The biggest i would want to run is 33x12.5's, possibly up to -51mm offset
  2. Dec 4, 2021 at 3:19 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
  3. Dec 4, 2021 at 3:20 PM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    What’s your set up and what are you looking to do after lift… Gen, drivetrain, mall crawler, trails, rock climbing??
    I can’t speak for all… but as for 3rd Gen’s, anything more than 2.5” of lift is just asking for problems… CV boot issues, alignment issues, lots of cutting and possibly welding (cab mounts), the list goes on. If you just want a big a** Taco, go with the 6”. But I know with the 3rd Gen again, you’ll have to cut out the factory cross member. That right there will void many warranties and coverages. Not to mention kill the resale value if you ever decide to go with a new rig. Definitely do your research first!! You can achieve 33’s without using 4-6” lifts and removing factory cross member. If you want to go that route, spend the money right and just do a solid axle swap in the front!
    Hope this helps. Keep us posted on what you decide.
    Gunshot-6A likes this.
  4. Dec 4, 2021 at 3:22 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    3" and the Sawzall. Good luck with your truck.
  5. Dec 4, 2021 at 3:41 PM
    tacomanyo
    6 inch thing is cut
    my cross member is gone already bois, i have a rough country 6" lift on it right now but want to switch before I encounter any issues
  6. Dec 4, 2021 at 3:53 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Ah, well that’s a different story then… what’s wrong with the RC lift? If it’s just age, you could always send the hardware out to blast and re-powder, and then just add some nice Kings to what you already have.
    :spending:
    tacomanyo[OP] likes this.
  7. Dec 4, 2021 at 3:56 PM
    tacomanyo
    6 inch thing is cut
    I want to put 33's, have on 35's right now because I went full retard and they are too big. Thinking of lowering the truck too and getting a 4" kit. Will probably just get the 2500 buck BDS kit with Fox, Kings I cant find in stock anywhere but hey if you can let me know bro
    Taco1004[QUOTED] likes this.
  8. Dec 4, 2021 at 5:50 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    It was still Friday on the international date line two hours ago
  9. Dec 6, 2021 at 7:18 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    If you go with the BDS kit, Fox shocks is your best bet and something we can help you source. King doesn't make a shock set for that tall of a lift.
    tacomanyo[OP] and Gunshot-6A like this.
  10. Dec 6, 2021 at 10:59 AM
    tacomanyo
    6 inch thing is cut
    Awesome! So I could use a BDS 4" kit and you could get some fox coilovers that would work for 4"?
  11. Dec 6, 2021 at 12:38 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I've got a 100% complete full Fabtech 6" kit for sale.
    Full length 6" lift Fox resi coilovers for the front, fox 2.0 shocks for the rear, and full leaf packs for the rear. No blocks or spacers. If you're in Colorado I'd give it to ya for cheap...
  12. Dec 6, 2021 at 1:03 PM
    AccuTune Offroad
    El Cajon, CA
    Yes we can
    tacomanyo[QUOTED][OP] likes this.
  13. Dec 6, 2021 at 1:32 PM
    tacomanyo
    6 inch thing is cut
    will think on this, thanks! Im in NC so that kind of limits things tho
    reg0928[QUOTED] likes this.
  14. Dec 6, 2021 at 1:37 PM
    tacomanyo
    6 inch thing is cut
    That's awesome! So in the BDS 4" kit, it comes with two Fox shocks it looks like, could i just move those to the rear suspension and use some of your coilovers in the front instead?
    BDS 4" kit: https://bds-suspension.com/kit-customizer?kid=822FS
  15. Dec 6, 2021 at 2:03 PM
    AccuTune Offroad
    El Cajon, CA
    Sorry, for some reason I had it in my mind BDS uses the same coilover for their 4" and 6" kits. Their 4" kit only includes a large spacer to use along with a stock coilover. Unfortunately I am not able to confirm if the longer coilover can be run at that short of a lift height. We could set you up with a standard length Fox coilover to use along with their spacer. You would still get that lift height and still get a quality ride from the tuned shocks. Shoot is a message if you would like some more details on this setup
  16. Dec 14, 2021 at 3:12 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Tons of Tacoma's running those tires on a 6" lift here in Hawaii. No issues.
