Debating with myself
Discussion in 'Wheels & Tires' started by toyoTRDtaco, Aug 15, 2011.
  1. Aug 15, 2011 at 7:07 PM
    toyoTRDtaco
    toyoTRDtaco [OP] Well-Known Member
    NB, Canada
    2006 Double Cab TRD Sport
    So Im debating wheather or not to purchase a set of Roto's. What Im looking to get is a set of;
    1) Rota Grid Off-Road, 16x8, 6x139.7
    2) Rota Grid Type B, same size
    3) Rota Grid Type X, same size
    I couldnt find any specs on the back spacing. Im really new to the truck rim world and a little confused. Im thinking the the stock offset is +20 on my 06 TRD Sport Double Cab. The Rota's come in +10, +15. Will that look alright on my truck? Will they stick out to far, or be sunk in?
    I do plan on going with a 3" lift within the next year as well, im not sure if that makes a different or not but I would like to get a little help from the knowledgable members here on the board.
    Thanks
  2. Aug 16, 2011 at 10:03 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    So, you're on TW to debate with yourself? You're going to get interrupted by smart asses like me;)
  3. Aug 16, 2011 at 12:35 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Eibachs w/ 5100's set at 0, Rear TSB, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, 265/75/16 Hankook Dynapro ATM Tires, Elusive Elements Mesh Grill
    Wasn't aware rota made truck wheels. They look like konigs. How do they compare to konigs?
    OP, I know there is a chart on here that converts the offset and bolt pattern to the backspacing. Unfortunately, I'm on TW through the phone so can't really get you the link to it.
  4. Aug 16, 2011 at 12:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Stock offset is +25 mm on the TRD sport wheels, which is 5.25" backspacing on 7.5" wide wheel.
    We need to know the tire size you plan on running in order to know which offset is best for you.
  5. Aug 16, 2011 at 12:48 PM
    KPT
    09 Prerunner
    I would imagine they do not compare favorably in any category except price.
  6. Aug 17, 2011 at 12:12 PM
    toyoTRDtaco
    NB, Canada
    The plan is to have 265/70/16. This is the reply I got back stating the offsets of each.
    "1 grid offroad *+ 10, concave spoke
    2 grid type b and type x, similar model.
    Grid Type B +10 offset
    Grid Type X +5 offset *or-5"
  7. Aug 17, 2011 at 12:56 PM
    KPT
    09 Prerunner
    The only one of those that will allow you to ever run anything more than a 265 would be the -5 offset. If you always plan to run 265's then any of those would work.
