Debugging the Curt Echo Mobile 51180 Brake Controller
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trailerguy, Jun 17, 2021.
  1. Jun 17, 2021 at 2:56 PM
    trailerguy
    trailerguy [OP] Active Member
    2021 Tacoma SR5
    Just solved my problem and wanted to share with you all.
    I've used my Echo Mobile brake controller (like this https://www.curtmfg.com/part/51180) for over a year and it worked fine with a Honda Ridgeline and a Ford F250. But with my 21 Taco I couldn't get left blinker to work nor the brake engaging.
    To debug I used voltmeter to check the right/left blinker pins on truck connector first (see connector flip cap for wiring diagram) and confirmed working, then plugged in controller and checked same pins on controller to verify left not pulsing. You'll see voltmeter switch from 12v to something close to zero every time the blinker should flash.
    Called up Curt tech support and they recommended dielectric grease and that did the trick! So I first cleaned up controller pins with sandpaper, then some rubbing alcohol, then added the grease. And now it works.
    Hope I can save someone some time in the future.
  2. Jun 17, 2021 at 3:25 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Good tip!
    I (and hopefully others) appreciate that you took the time to post this.
    Have a great weekend!
    trailerguy[OP] likes this.
