decal removal from 8 yr old tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeftCoastNerd, Mar 28, 2016.
  1. Mar 28, 2016 at 10:48 PM
    LeftCoastNerd
    LeftCoastNerd [OP] Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    so I just got a 2008 tacoma, 'silver streak', its a TRD Off Road, and I'm thinking of removing the rear badges and decals to go for a cleaner look...
    has anyone removed those big fugly TRD decals from a truck that was already a halfdozen+ years old? do they come off clean, or did you regret it? what assistance did you use to remove them, hot air gun, chemicals, plastic scrapers, or what?
    this one has always been garaged, so its fairly pristine, and has no sun damage.
  2. Mar 28, 2016 at 11:32 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You might just let it sit in the sunlight on a warm day and then see if you can peel back a corner. If there is any residue, you can use a light petroleum based degreaser like Goo Gone or Odorless Mineral Spirits to clean up. Be sure to wash and wax after to protect the now-virgin paint.
  3. Mar 29, 2016 at 12:29 AM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    I shoulda googled before I posted, hah. I found a thread here from a couple years ago, hair dryer, don't burn the paint, and they should lift right off. Or use some 3M Striper wheel thing. Or just peel off. then use goo-b-gone, polish, wax.
    https://www.tacomaworld.com/threads/removing-trd-stickers.188168/
    I live on the central left coast, and actual hot days are fairly rare until mid summer, so I'll probably try the heat gun thing. I suppose the resale value is better if the decals are pristine.
  4. Mar 29, 2016 at 12:42 AM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Just gonna warn you, this is something we encountered a lot at the dealership, old badges and such on trucks. I debadged most of mine, left two... The washer guys would heat them up, and use fishing wire to get the main parts of the badge off. Then, would use a razor blade to get most of the residue off (scared me too, don't worry) then buff the rest out. However, at extreme close examination, you can still see the outline where the paint has faded and the new exposed paint still says "SR5" ect. Luckily, I have scratches everywhere else so no one looks too close.
  5. Mar 29, 2016 at 1:14 AM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    awww, you couldn't buff that out? :alien:
  6. Mar 29, 2016 at 9:07 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Do you know for a fact the clearcoat goes on after the badges/etc.?
  7. Mar 29, 2016 at 9:09 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
  8. Mar 29, 2016 at 11:16 AM
    2015WhiteOR
    Gainesville TX
    Sorry I didn't intend to imply that the clearcoat goes over the decals. When I said "now-virgin paint" I meant how that part of the paint has been covered by a decal for the last 8 years and hasn't been polished or waxed.
  9. Mar 29, 2016 at 12:08 PM
    KeptOnChooglin
    Phil
    Houston, TX
    True, and I dont know what the reaction of the adhesive to the clearcoat would be, possible bonding so when the adhesive goes, so does some of the clearcoat.
  10. Mar 29, 2016 at 12:12 PM
    KeptOnChooglin
    Phil
    Houston, TX
  11. Mar 29, 2016 at 12:17 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    I've done it before. There's always a risk and one time I could tell at a certain angle that the paint was not pristine but no one else could.
    I use a heat gun and a plastic razor blade. Go slow. Use gasoline to clean up any residue. Then wax and polish.
  12. Mar 29, 2016 at 12:18 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
