Deceleration clunk/surge...TSB?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pbird74, Jan 8, 2019.
  1. Jan 8, 2019 at 2:09 AM
    Pbird74
    Pbird74 [OP] Well-Known Member
    17MGMDCSR54x4
    Off Road Bilsteins, Pro grille
    So my 2017 is occasionally surging and clunking under deceleration (sort of like a bump from behind by another vehicle). I remember this being discussed, but I could not find the thread. Does anyone know if there is a TSB for this condition?
  2. Jan 8, 2019 at 2:11 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Was your gas tank partially full when you experienced this?
  3. Jan 8, 2019 at 2:17 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
  4. Jan 8, 2019 at 2:19 AM
    soggyBottom
    soggyBottom Well-Known Member
  5. Jan 8, 2019 at 2:33 AM
    Pbird74
    17MGMDCSR54x4
    Nope. Full tank.
  6. Jan 8, 2019 at 3:00 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    For context, I've occasionally had the "bump from behind by another vehicle" clunk, but usually right after I reach a complete stop. Always thought it was axle wrap or gas tank shift.
    I don't have the bipolar slushbox.
    TacomaCZman likes this.
  7. Jan 8, 2019 at 4:44 AM
    gearcruncher
    Canadain bumper technician
    Amanelot likes this.
  8. Jan 8, 2019 at 5:01 AM
    TimC
    TimC Well-Known Member
    NY
    Same thing with FJ cruisers. I call it the bump stop. You’d swear someone tapped your rearend at a stoplight.
    My ‘08 did it most of the time. Greased driveline and flushed tranny. Still does it. My ‘12 FJ has never done it..
  9. Jan 8, 2019 at 5:04 AM
    gearcruncher
    How did you lubricate your splines on the slip yoke ?
  10. Jan 8, 2019 at 5:05 AM
    TimC
    NY
    Dropped the driveshaft
  11. Jan 8, 2019 at 5:08 AM
    gearcruncher
    :thumbsup: What type of lubricant did you use to grease the splines ?
    TimC[QUOTED] likes this.
  12. Jan 8, 2019 at 5:11 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    My FJ does it too. Sometimes right after I grease the driveshaft it goes away for a bit.
    There was a TSB out for the early FJs, but I was over mileage when I tried to get it fixed. I just live with it.
    gearcruncher and TimC like this.
  13. Jan 8, 2019 at 5:12 AM
    TimC
    NY
    If I recall it was LuberPlate (sp) brand. Waterproof grease. White colored stuff.
    Used it on trailer bearings as well
    gearcruncher[QUOTED] likes this.
  14. Jan 8, 2019 at 5:19 AM
    gearcruncher
    The lubricant on your driveshaft splines is expensive stuff . If you lube your splines up with grease , it will last for 2 days and simply get pushed off the splines .
    When you purchased your truck from the factory , Toyota didnt use enough of the expensive lubricant on the driveshaft splines and as a result , a lot of members here continue to experience this issue .
    There are 3 products listed at the bottom of my low fluid thread . Try some on your splines and report back
    TimC likes this.
  15. Jan 8, 2019 at 5:26 AM
    TimC
    NY
    Ford lube! lol:facepalm:
    I’ll pick some up to have on hand and lube-up the Fj
    gearcruncher likes this.
  16. Jan 8, 2019 at 5:33 AM
    gearcruncher
    Hahahaha , Ford lube is the cheapest out of the bunch lol but if it works , use it .
    Spicer still has the contract for making the driveshafts in the Tacoma , Ford , Dodge and General Motors .
    When Toyota assembled your truck , they were a little shy on the expensive lube for the splines
    TimC and MOC221_ like this.
  17. Jan 28, 2019 at 8:38 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Have we figured out what’s causing this? Is it the drive shaft? Mine does it every once in a while. The dealership “cannot duplicate”
  18. Jan 28, 2019 at 9:02 AM
    DHerrm
    DHerrm Well-Known Member
    Daniel
    2018 SR5
    I've taken my 2018 2wd in for this 4 times. Times 2-4 they tell me it's supposed to do what mine is doing.
