Deciding between two lift kits...
Discussion in 'Suspension' started by cbb530, May 30, 2009.
  1. May 30, 2009 at 7:45 AM
    cbb530
    cbb530 [OP] Member
    Raleigh
    2000 PreRunner SR5-Extra Cab
    Bed-Liner Nerf Bars Black Honeycomb Grille
    I have a 2000 PreRunner extra cab. I wanted a little lift and a level look to go with it. I bought 31's about a year ago so I don't want to get new tires for a while. I've been reading threads on here for a while and I think I am hung up on two lift options
    1) Bilstein 1500's all the way with the front set at 1.75 (or 2.5?) with the AAL in the rear
    2) 3" lift kit with OME front coils and rear lift options from toytec
    I was leaning toward the OME because I do haul some heavy lawn equipment in my truck and the rear sags down quite a bit. I was wondering if I put the stiffer coils in the rear if that would help me out with that.
    Overall though I want a lift that gives me a little lift with the level look. I don't want the spacers lift even though I don't go off roading.
  2. May 30, 2009 at 7:47 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you cant put stiffer coils in the rear without a bunch of fabricating...youre not coilsprung...youre leafsprung
  3. May 30, 2009 at 7:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What he^ said...
    You can get an AAl or a complete replacement leaf pack.
  4. May 30, 2009 at 2:32 PM
    cbb530
    cbb530 [OP] Member
    Raleigh
    So should I get the Bilstein shocks all around with the AAL in the rear? What should I set the front shocks at if I want to level it out? I've heard people say 1.75 and other 2.5...but some people say the 2.5 is a stiff ride.
  5. May 30, 2009 at 2:37 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I think 1.75" in the front should level it out with the TSB springs. If you set the Billys to 2.5", you'll probably need an AAL in the back to keep it level.
