Deciding Between Wheelers Progressive add-a-leaf regular version vs Heavy duty
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deere9798, Dec 30, 2014.
  1. Dec 30, 2014 at 8:22 AM
    Deere9798
    Deere9798 [OP] Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Hello Tacoma World. I have been trying to decide between the Wheeler’s Multi-Leaf Add A Leaf Set – 1.5″ Lift 3 Leaf Progressive and Their Heavy duty version.
    I have a regular cab 2001 2.7 4x4 truck with the 4 leaf pack including the overload. It has an ARE topper on it and I do a fair amount of towing/Hauling, some light off roading also.
    Should I get the regular version or the heavy-duty version?
    Thanks,
    Charlie
    Links to the Add-A-Leaves:
  2. Dec 30, 2014 at 6:00 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    if i had your truck i would go with a non HD set.. 4cyl reg cab is a light truck and the HD leafs will give it a harsh ride
  3. Dec 30, 2014 at 6:20 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks for your input. During the winter the roads can be very rough and pot holed. Would the non HD soak up the bumps better than the HD one?
    Also a rear plate bumper may be in my future.
    Thanks,
    Charlie
  4. Dec 30, 2014 at 8:00 PM
    DSMJRV
    justin
    Corona, CA
    absolutely will.. but you already have a topper, and if you have a full time toolbox in there and a plate bumper etc. then the HDs wont ride all that bad. it just depends on you, do you mind a stiff ride? can you put up with a stiffer ride knowing that your towing and hauling purposes are going to be more comfortable and stable?
    i have HDs but have always preferred a stiff ride with less body roll, and my off road application is mostly high speed where i don't need a lot of articulation.. however when i added a toolbox with 200lbs of gear and mounted a high lift jack it did make a difference.
    its a trade off really, you just gotta know what you can and cant compromise on..
  5. Dec 30, 2014 at 8:06 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Topper alone warrants the HD AAL. Although with a rear plate bumper in your future a new leaf pack would be a better option.
  6. Dec 30, 2014 at 8:48 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Well it sounds like HD it is. Thank you to every ones suggestions,
    they were very helpful.
    Thanks,
    Charlie
  7. Dec 31, 2014 at 12:06 PM
    c99ae86
    c99ae86 Well-Known Member
    north bay-bay area
    04 trd taco
    deckplate, debadged
    anybody run the HD pack with the eibach/bilsteins lift? I was thinking about getting the 5100's all around and using the HD pack instead of the single AAL. I run a full time topper too along with light towing.
  8. Sep 6, 2015 at 12:28 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    UPDATE
    I choose the HD version and I have been very pleased with their performance. They handle weight well and although the ride is stiffer it is also better.
    _Charlie
    because_wumbo-truck likes this.
  9. Sep 7, 2015 at 1:00 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I used the Wheeler's HD packs and liked them as well.
  10. Sep 7, 2015 at 9:33 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I bought the HD's for my 99 ext cab and my 03 dc both v6. I think for the extra 10 bucks it's good piece of mind. Just my 2 cents
