Deciphering codes P0171 and P0325 - knock sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jamjar99, Aug 23, 2017.
  1. Aug 23, 2017 at 10:10 AM
    jamjar99
    jamjar99 [OP] Member
    I know that these codes P0171 System too lean bank 1 and P0325 Knock sensor circuit bank 1 are usually due to a faulty knock sensor and/or wiring harness. They can also be caused by some other components I believe.
    The check engine light comes on under a heavy acceleration only, usually it lasts a day or two before coming back on.
    However, is there a way to use a OBDB reader to pinpoint more accurately where the issue might be?
    I've read that maybe the Fuel trim readings are a good place to start.
  2. Aug 24, 2017 at 10:48 AM
    Skilluh541
    Skilluh541 Well-Known Member
    2004 Toyota Tacoma Prerunner 2.7L 4 Cyl
    Cold Air Intake, 3" Lift
    I have been dealing with a P0171 for awhile now, I have been told many many times that it is more than likely a vacuum leak somewhere. I have yet to find my "leak" but my truck is still running well enough.
    What are your symptoms?
  3. Aug 24, 2017 at 6:00 PM
    Glamisman
    Glamisman Well-Known Member
    on 3.4's toyota uses a metal gasket for both the upper and lower intake... dont remember on the 4 cylinders, anyway, it is metal so that it will not suck through. If you have an aftermarket fibre type upper or lower there is a possibility that it has vacuum leak at either. Same thing goes for the throttle body to upper intake.
    If the EGR system is not functioning as designed by either a broken vacuum line or blockage the combustion temps will be too high and that can induce a knock also. This is just one of those things that you are going to have to spend some time with.
    Skilluh541 likes this.
  4. Aug 27, 2017 at 9:25 PM
    Skilluh541
    Yea after changing the spark plugs it is running well enough for me to drive but I definitely need to find it because it is bugging me that there is something wrong. Hopefully this coming weekend I will retighten the bolts on the cat that I swapped and make sure that the gaskets there are sealing.
  5. Aug 27, 2017 at 10:20 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I also get P0171 after heavy acceleration or climbing grades. Once I clear it, it only appears again during the aforementioned variables. I think it's due to a dirty MAF, or a bad O2 sensor.
