Deciphering the VIN
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mphatik, Oct 14, 2015.
  1. Oct 28, 2015 at 7:07 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    1-3 WMI:
    5TF = USA Production
    3TM =Mexico Production
    4: Cab/Drive/Grade/Bed Size
    A = Double Cab 2WD SR/SR5/TRD Short Bed
    B = Double Cab 2WD SR5/TRD Long Bed
    C = Double Cab 4WD SR/SR5/TRD Short Bed
    D = Double Cab 4WD SR/SR5/TRD Long Bed
    E = Double Cab 2WD Limited Short Bed
    F =Double Cab 4WD Limited Long Bed
    G = Double Cab 4WD Limited Short Bed
    R = Access Cab 2WD SR/SR5/TRD
    S = Access Cab 4WD SR/SR5/TRD
    5: Engine
    X = 2TR-FE (2.7L L4)
    Z = 2GR-FKS (3.5L V6)
    6: Version
    5 = 2016+
    7: Chassis Code/Wheelbase
    G = TRN265 (2.7L 2WD 127.4 in Wheelbase)
    C = GRN325 (3.5L 2WD 127.4 in Wheelbase)
    D = GRN330 (3.5L 2WD 140.6 in Wheelbase)
    E = TRN245 (2.7L 4WD 127.4 in Wheelbase)
    A = GRN305 (3.5L 4WD 127.4 in Wheelbase)
    B = GRN310 (3.5L 4WD 140.6 in Wheelbase)
    8: Model
    N = Tacoma
    9: Check Digit
    X,1,2,3,4,5,6,7,8,9,0
    10: Model Year
    G = 2016
    11: Plant
    X = TMMTX Plant (San Antonio, Texas)
    M = TMMBC Plant (Baja, Mexico)
    12-17: Sequential sequence number
    Sequential sequence number restarts at 1 for each chassis code at each plant and does NOT restart with every model year.
    TRN245-M000001
    TRN245-X000001
    TRN265-M000001
    TRN265-X000001
    GRN305-M000001
    GRN305-X000001
    GRN310-M000001
    GRN310-X000001
    GRN325-M000001
    GRN325-X000001
    GRN330-M000001
    GRN330-X000001
    Note that the TRN245 and TRN265 are still the same chassis as the 2005-2015 Tacoma so their sequence has NOT restarted for 2016, all 2.7L models for 2016 are continuing from where 2015 left off. Only 3.5L models got new chassis codes due to the engine block change from 1GR to 2GR.
    Jeff
    jkl16, redstripesailor and NoDak like this.
  2. Oct 28, 2015 at 7:08 AM
    Jeff Lange
    Calgary, Canada
    Currently information from Toyota Canada states that all of our 2016 Tacomas will be coming from Texas, currently no Canadian models are made in Mexico.
    Jeff
