Decision Time: Stock 4x4 or 5-lug with lift and locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by hobo_hut, Aug 20, 2010.
  1. Aug 20, 2010 at 8:40 AM
    hobo_hut
    hobo_hut [OP] Member
    My beloved 99 4x4 didn't pass the rust inspections so needless to say its time to shop for a new truck, but I can't decide what I want so hopefully you all can help me out. The only thing for sure is that the truck must be regular cab 4cyl with manual transmission. My max budget is 8K. For the 5-lug I'd be doing all the mods my self.
    Option 1:
    01'-04' 4x4
    Reg Cab
    5 spd
    Option 2:
    01'-04' 4x2 5 lug
    fabtech or doetsch 3" or 6" lift
    Re-gear
    Locker
    30's or 31's
    Option 3:
    2nd Gen 5 lug
    3" lift
    30's
    I don't do a whole lot of wheel'n...I have a dirt bike for real off road stuff. The lift would mostly be for aesthetics but I would be doing the occasional trail. Nothing too hard core though.
    Also I would be using the truck for towing a small boat regularly. The boats I tow weigh around 2000-2500 lbs.
    A few additional things i'd like some insight on about the 5 lug:
    -Will the 5 lug handle light trail use and small trailer towing with is lighter built frame/suspension and smaller brakes?
    -Is the transmission the same in the 5 lug as the 4x4?
    -What kind of rear end does the 5-lug have? Locker/re-gear availability?
  2. Aug 20, 2010 at 8:52 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    IMO i would go with option 1. You will regret having the 5-lug, because if you are going to tow your boat that v6 will come in handy more than a I4 (not saying the 4cyl is under powered). The Reg cab V6 has a different transmission than the I4 5 lug. The rear end of the 5 lug is LSD, people put lockers in 5 lugs before. If you go with option 2 you will more than likely have to regear your rear end with 4.88s because trust me if you buy a 6 inch lift you will be tempted to buy bigger tires than 30s or 31s.
  3. Aug 20, 2010 at 10:01 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    A jacked up 5-lug is about the worst thing I've seen. There's a reason it's only a 5-lug, it's not made for heavy rims/ tires and with a lift the towing capacity will be shit.
  4. Aug 20, 2010 at 10:05 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    option 1
  5. Aug 20, 2010 at 11:29 AM
    hobo_hut
    I should have added that it will be a 4cyl no matter what. I currently tow with my 99 4cyl 4x4 and I'm happy with it. Most of the time I will only be towing a small boat under 1000lbs so I don't really need the v6. An I'm positive I have enough self control to not put anything bigger than 31's on any of the options.
  6. Aug 20, 2010 at 11:34 AM
    hobo_hut
    I didn't realize that 01-04 5 luggers had lsd...nice to know. It's kinda hard digging up info about the 5 lugs.
  7. Aug 20, 2010 at 11:34 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    They definitely don't. (You should have seen what happened right after the pic in my sig line)
  8. Aug 21, 2010 at 12:19 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    The only difference between the 6lug 4x4/prerunner and the 5lug would be the suspension, obviously, fenders/bedside, and transmission (5lug should just be the 2wd version of the 4x4 transmission). Someone let me know if what I'm saying is wrong or I'm forgetting something lol
  9. Aug 21, 2010 at 12:20 AM
    kmok
    Kyle
    Columbus, Ohio
    A jacked up 5 lug would basically be a prerunner that needs regeared...
  10. Aug 21, 2010 at 1:33 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    5 lug is do-able with towing and larger tires. If you do large tires, re-gear is a must! I tow about 1500 lbs and still moves fine. It's no pulling monster, but works for the jobl_894411f3e90c41af90e91193362ac4fb_34174b00ea11dd2a0df4f31e98271aab2dcdeb00.png
  11. Aug 21, 2010 at 4:27 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
  12. Aug 21, 2010 at 4:28 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    6 lug TRD with a locker FTW!!
  13. Aug 22, 2010 at 12:05 AM
    MowTaco
    Kansas
    Definitely go 4X4... I can't tell you how many times I've been digging through my toolbox for a tow strap wishing I had 4X4. I went 2wd for the gas mileage of the 2.4... not nearly significant enough to offset being shorter than a damn camry
  14. Aug 22, 2010 at 12:57 AM
    MadTaco461
    CA
    Kinda stock
    Hey I own a damn camry... the 5 lug tacoma doesn't compare to a camry. Camry's should be thrown off cliffs. Shame to saying a tacoma is like a camry. :eek:
  15. Aug 22, 2010 at 8:47 PM
    MowTaco
    Kansas
    I didn't say it was like a camry in any way but height. Although one kid said my truck was basically a camry with a bed. He still hasn't been found. :quickdraw:
    Anyway I just hate how I'm eye to eye with regular car drivers on the road. I'm hoping to change that soon...
  16. Aug 23, 2010 at 6:13 AM
    RattleTractor
    Harry
    VT
    What do you get for mileage?
    I'm getting 20-23 combined with a V6, 4x4, and 32s in the summer...
  17. Aug 23, 2010 at 6:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Correct, the 5-lug will also have slightly different gearing I believe. Also, a first gen 5 lug will have a 2.4L while the second gen 5 lug will have a 2.7L (since the OP is looking for a 4 banger).
  18. Aug 23, 2010 at 9:24 AM
    MadTaco461
    CA
    Kinda stock
    That already sounds like a happy ending to that story:taco:. You should look into getting some fabtech spindles and a 1.5" add a leaf when you got the $$$ saved up to do rims and tires.
  19. Aug 23, 2010 at 8:50 PM
    MowTaco
    Kansas
    I do! Just gotta get the old man to give me the green light... It is technically still his.
  20. Aug 23, 2010 at 11:13 PM
    MadTaco461
    CA
    Kinda stock
    The taco isn't in your name, bummer. Insurance is cheaper that way. If you are taking good care of it I'm sure he'll let a few mods every once in a while. It's addictive once you start.
    hobo_hut i :threadjacked: you. FYI if insurance is a deal too 5 lug is way cheaper in that department over 4x4.
