Decisions decisions!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bryanfrancoe43, May 5, 2024.
  1. May 5, 2024 at 11:15 AM
    bryanfrancoe43
    bryanfrancoe43 [OP] Member
    Bryan
    2004 Chevy colorado
    Alright tacomaworld I need some input on a decision between two tacomas one is a green 99 with 140,000 miles on it and the other is a light purple 2000 with 230,000 miles on it. The thing with the 99 is that it might need the valve cover gasket replaced. The 99 is selling for $6,700 and the 2000 goes for $7,300
  2. May 5, 2024 at 11:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Valve cover gasket is a rookie DIY, a non consideration.
  3. May 5, 2024 at 11:30 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    +1 on valve cover being non issue.. 140,000 mile 99. Has been babied too would be my guess, Which owner is older and retired? lol
  4. May 5, 2024 at 11:35 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Might be able to use the valvecover leak as a negotiating point also.
  5. May 5, 2024 at 11:45 AM
    bryanfrancoe43
    Bryan
    2004 Chevy colorado
    Really?
  6. May 5, 2024 at 11:59 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I wouldnt buy unless you can start it cold.....and watch for bubbles coming out radiator....
    And check for the white smoke.
    A lot of times they've been sitting for a reason...
    Engine 2.7 's ??.......both autos?
    I would lean towards the 99, unless it was poorly cared for.....ei oil burner....
    engine pics might reveal that....
    I'd be extremely invasive buying 25yr 7K truck....
    Id pull plugs.....and even compression test...
    with a tag team buddy you could do all that in less than 10min
  7. May 5, 2024 at 10:34 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Well done, 4 threads in 40 minutes. The green 99 seems like the better buy, you posted pics of the frame, looks clean, but regardless of what you plan to buy, you’d be wise to have it looked at by a reputable mechanic.
    ace_10 and T4R_hereforbearings like this.
