Deck plate mod finished!
Discussion in '1st Gen. Tacomas (1995-2004)' started by archerytarget, Apr 20, 2009.
  1. May 20, 2010 at 7:18 PM
    #81
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    will the deckplate mod throw a check engine light?
  2. May 21, 2010 at 10:19 AM
    #82
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    It will if you don't use sensor safe permatex gasket sealer. Otherwise you shouldn't get any errors.
  3. May 21, 2010 at 2:18 PM
    #83
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Just bought a 4" plate today and a k&n filter. Ready to complete the mod this weekend. Might have to use a jigsaw for the hole however.
    Been needing to get a k&n filter, so the mod cost a little more ;)
  4. May 21, 2010 at 2:58 PM
    #84
    04YodaTaco
    04YodaTaco Well-Known Member
    central NY
    04' Tacoma 4x4 base
    New frame mod. 265/75/16 Duratracs.
    I'm looking to do the deckplate soon in combo with the AFE filter. I have the 2.7l four banger. Could have sworn I read that the deckplate doesn't make much difference on the 2.7 compared to the 3.4 v6. Anyone with the 2.7 done the deckplate and would recommend it? Any difference in mpg or power? I don't want to bother cutting up the airbox if there isn't much difference.
  5. May 21, 2010 at 3:02 PM
    #85
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
    If you can post back with your results after installing the deckplate and filter I'd appreciate it. Would help me make up my mind about doing it with the 2.7
  6. May 21, 2010 at 5:14 PM
    #86
    strongwxnc
    Bostic, NC
    I've read some good reviews about doing the deck plate on a 2.7L. Which is why I plan to complete it.
  7. May 21, 2010 at 7:28 PM
    #87
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Check out this thread. Lots of great info and addresses your exact question about how much difference it will make on the 2.7L. See post #18.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/28812-explain-deck-plate-mod-please.html
  8. May 22, 2010 at 8:02 AM
    #88
    strongwxnc
    Bostic, NC
    In the process of completing it now. A 4" works fine. Cutting the ribbed section on the 2.7L box kind of sucks. I will install after family time :)
  9. May 22, 2010 at 8:47 AM
    #89
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
  10. May 22, 2010 at 8:55 AM
    #90
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
    Cool good luck with the install. My friend's family owns a marine store, gonna pick up a 4" deckplate. Probably will do the install next weekend.
  11. May 22, 2010 at 9:09 AM
    #91
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    There's so many questions as to which is the resonator, what's the best way to tape them off, etc..when I get home tonight I'm going to take mine apart and take pictures, post them here (if it's still daylight when I get home, otherwise tomorrow).
    The deckplate mod on mine, my butt dyno says it made a difference but then again my truck always feels like it runs better after I wash it. So tough telling.
    Taping off the resonators though, on my way back from Tampa yesterday I needed to put my foot into the pedal to get out of a 18-wheeler's way...and I LOVE the GRRRR coming from under the hood!
  12. May 22, 2010 at 2:47 PM
    #92
    strongwxnc
    Bostic, NC
    I was able to complete the deck plate mod for my 2.7L this afternoon.
    I used a 4" deck plate,
    Senor safe silicone
    6 3/4" pan head screws
    a Jig saw ( it was all I had)
    a metal file
    The ribbed places on the 2.7L air box was a little hard to deal with. But After I was able to file them down it was ok. I also taped off the senor (the one that inserts into the little black box. I plan to un-tape and test also.
    Total time was about one hour +.
    Just make sure you cut the hole where the plate and sidle into the hole in a easy manner. If not, you run the risk of throwing the plate off and the insert might not fit right.
    Here are some pics..
    The last one show how close the windshield fluid is..
