Deck plate mod. Here we go.
Discussion in '4 Cylinder' started by Matic, Aug 5, 2010.
  1. Aug 6, 2010 at 6:24 AM
    #41
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Ok. Finally some some pics.
    Unclip the 4 retainers holding the airbox lid on.
  2. Aug 6, 2010 at 6:26 AM
    #42
    Matic
    Tricky Dick
    Easley, SC
    Remove this hose.
  3. Aug 6, 2010 at 6:27 AM
    #43
    Matic
    Tricky Dick
    Easley, SC
    Now remove your air filter. Sorry, This is my K&N and not the stock filter. For reference only.
  4. Aug 6, 2010 at 6:28 AM
    #44
    Matic
    Tricky Dick
    Easley, SC
    I decided to go with a K&N Hi flow element. Stock on the left. K&N on the right.
  5. Aug 6, 2010 at 6:32 AM
    #45
    Matic
    Tricky Dick
    Easley, SC
    I decided to get 2 different size deck plates. A 4in and a 6in.
    I thought maybe I would try cutting the bottom of the airbox out as well as the metal below it and putting some kinda of ram-air system in. I nixed that idea and went with the reg mod. I may try the other later on.
    The inverter isn't part of the install. I just happened to pick it up while getting my deck plates.
  6. Aug 6, 2010 at 6:34 AM
    #46
    Matic
    Tricky Dick
    Easley, SC
    Remove the 3 12mm bolts. 2 on the bottom and 1 on the top.
  7. Aug 6, 2010 at 6:35 AM
    #47
    Matic
    Tricky Dick
    Easley, SC
    Viola!!
  8. Aug 6, 2010 at 6:36 AM
    #48
    Matic
    Tricky Dick
    Easley, SC
    The 4 inch deck plate is a perfect fit.
  9. Aug 6, 2010 at 6:39 AM
    #49
    Matic
    Tricky Dick
    Easley, SC
    Now with a marker, draw around the outside of the hole. You may need to trim and the cleaner your cut, the tighter it will fit.
  10. Aug 6, 2010 at 6:41 AM
    #50
    Matic
    Tricky Dick
    Easley, SC
    Drill a pilot hole to start a dremel or jigsaw. I used a jigsaw in this case.
  11. Aug 6, 2010 at 6:43 AM
    #51
    Matic
    Tricky Dick
    Easley, SC
    The jigsaw cut it like butter and I was pleased with the results.
  12. Aug 6, 2010 at 6:46 AM
    #52
    Matic
    Tricky Dick
    Easley, SC
    This is the original intake tube that goes into the fender. You can choose to leave this on if you like. I decided to go ahead and drill out the rivet for now. You can always put it back on later.
  13. Aug 6, 2010 at 6:47 AM
    #53
    Matic
    Tricky Dick
    Easley, SC
    Perfect fit.
    scottalot likes this.
  14. Aug 6, 2010 at 6:48 AM
    #54
    Matic
    Tricky Dick
    Easley, SC
    Run you a bead of sensor safe silicone around the edge.
  15. Aug 6, 2010 at 6:50 AM
    #55
    Matic
    Tricky Dick
    Easley, SC
    Clean up around the edges. I used short 1/4 in screws to attach the ring.
  16. Aug 6, 2010 at 6:53 AM
    #56
    Matic
    Tricky Dick
    Easley, SC
    I didn't really time myself on the install because I also installed my hi-lift jack mount as well. I would say maybe 45mins-1 hour for just the deck plate mod. Maybe 3 hrs for both. lol.
  17. Aug 6, 2010 at 6:55 AM
    #57
    Matic
    Tricky Dick
    Easley, SC
    Check your fit on your lid. Remove lid and toss it under your seat.
  18. Aug 6, 2010 at 6:57 AM
    #58
    98tacoma27
    Ben
    Not Beech Creek
  19. Aug 6, 2010 at 7:04 AM
    #59
    Matic
    Tricky Dick
    Easley, SC
    Re install the 3 12mm bolts. Install your air filter. Close the 4 clips and hook the rubber hose back up to the right side of the airbox.
    Very easy mod. Some say to go ahead and remove your neg battery cable for a minute or two so that the ECU can reset itself and re learn the new air intake.
    I personally don't feel any difference in hp. It is just a hair louder up in the intake area but hardly anything I am concerned about. I was hoping to atleast be able to powerbreak the rear end loose with all this extra horsepower that I now have. Unfortunately no. It may have done it before I put my powertrax locker in but there's just not enough power to smoke both of em.. :) Enjoy.
  20. Aug 6, 2010 at 7:06 AM
    #60
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    your pics and info are too good
    you werent drunk enough....:D
