Deck plate mod. Here we go.
Discussion in '4 Cylinder' started by Matic, Aug 5, 2010.
  1. Aug 9, 2010 at 8:14 AM
    #81
    Choreboy
    Choreboy Balls Deep
    Stephens City, VA
    2001 Tacoma SR5 XCab 2wd 2.4 Manual
    Just ordered my deck plate and K&N High Flow this morning.
  2. Aug 9, 2010 at 8:24 AM
    #82
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    What is the advantage of this mod?
  3. Aug 9, 2010 at 10:51 AM
    #83
    Choreboy
    Choreboy Balls Deep
    Stephens City, VA
    From what I gather it's about the same as adding an aftermarket intake minus the spending $200+
  4. Aug 9, 2010 at 10:51 AM
    #84
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    It's a pretty easy mod. If you need anything, just holler.
  5. Aug 9, 2010 at 11:04 AM
    #85
    Matic
    Tricky Dick
    Easley, SC
    Choreboy is correct.
    Basically you are cutting a large hole in your airfilter box to allow more air into the intake with the option of closing it off during river fording ( trust me.....If the water gets high enough to get in here with a 3in lift.....you've got other problems to worry about). or extreme dusty/dirty conditions. The hole is still below the filter so there's not much of a chance of anything getting into the throttle body. The only other thing I see that would benefit this is a strait pipe from the box to the throttle body. Something smoothbore to allow the air to travel faster without the bends.
    I also suggest running this system for a day or two without disconnecting your neg ground wire on your battery to see if you can "feel" a bit of difference.
    Then after a few days, disconnect your neg grd battery cable for 20mins to let the ECU learn the fuel/air mixture quicker. Hook it back up and go for a test run. Let me know what you think.
    This mod realistically is good for maybe 3-7 hp.
    I could see that if maybe paired with a set of headers. +7. Maybe 3-5 without.
  6. Aug 11, 2010 at 10:33 PM
    #86
    efmugen
    efmugen Well-Known Member
    Los Angeles,CA
    1996 Tacoma Single Cab
    Bingo !
  7. Aug 13, 2010 at 12:37 PM
    #87
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    shit thats funny! needed that today..
  8. Aug 23, 2010 at 12:00 AM
    #88
    Marfan1007
    Marfan1007 I play with poo.
    MS Gulf Coast
    Silver Prerunner TRD Off Road SR5
    -Hunter Bull Bar -Black Stallion Taillight Grill Guards -Pioneer AVH-4200DVD Pioneer 3 way door speakers, Pioneer amp and shallow 10" sub -Tonnopro bed cover -Ambient floor lighting
    Hells yes! When most people are goin to work, I'm just gettin off n crackin open a cold one. Nothin like a lil nightcap @ 7am:cheers:
  9. Sep 6, 2010 at 3:26 PM
    #89
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I might just be in the minority here, but I've tried both a KN intake system and the airbox mod here, and I actually prefer the stock system. The KN was just louder with worse low RPM performance, and with the deck plate open I consistently get about 3-4 mpg less and worse performance below 5,000. I don't know, guess my particular truck just likes things the way they came from the factory.
  10. Sep 6, 2010 at 7:17 PM
    #90
    Barnone
    Barnone Guest
    So when your truck gets more air the performance suffers?
    Might have a sticking EGR or something wrong in the fuel system to cause your truck to run lean. Getting any codes?
  11. Sep 9, 2010 at 3:17 PM
    #91
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Nope, no codes and I have a scangauge hooked up and it doesn't have anything in it code wise. I didn't think about the EGR system, I've got 160,000 miles on it and I think it's the original fuel filter still, maybe I should look at replacing that and see if it makes any difference.
  12. Sep 24, 2010 at 5:59 AM
    #92
    00tactrouble
    00tactrouble Active Member
    South Texas
    2000 Toyota tac prerun
    New Dakota A/T tires in 31x10.50-15", 2 coat Rhino Liner on the the bed, Mossy Oak package interior, 8" bazooka system pumping my jams, Platinum system plugs underneath the hood with Gates belts keeping it turning, 6" deckplate mod and amsoil is keeping this thing lubed year around.
    too cool, enjoyed the step by step with the pics!
  13. Jun 9, 2011 at 8:56 AM
    #93
    Matic
    Tricky Dick
    Easley, SC
    Bump for the nublets.
    scottalot likes this.
  14. Apr 25, 2019 at 11:10 AM
    #94
    Tartan Jack
    Tartan Jack Rockin It Old School
    Clinton, SC
    “Sports Cart” -1995 Taco, 2.4 2wd, Manual Everything
    Interior “retroficaton” (in progress) Airbag removal (1st gen/high explosive type) Hard Tonneau (on it when I got it) New grill, with custom badge Light Steelies S-Runner suspenion
    This was 9 years ago ...
    Updated thoughts?
    Still like it?
    Would you do it again?
    Matic[OP] likes this.
