Deck Plate mod problem. Help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SirVaysa03, Jul 8, 2009.
  1. Jul 8, 2009 at 8:57 PM
    SirVaysa03
    SirVaysa03 [OP] Member
    Central Cal
    03 Tacoma Prerunner TRD Quad Cab Black
    Ok so i got a deck plate and installed it per what ive read up on here. Pretty simple, take out air box, cut out hole, slap in deckplate, reinstall airbox, and reconnect everything. I turned on the truck and the check engine light stayed on. I did forget to reconnect the airflow sensor when i turned it on first and it shut off, stupid i know. but i reconnected it and started it up again and it runs fine but engine light still on. Anyone got any ideas as to why its still on could i have jacked something up, help guys, thanks.
  2. Jul 8, 2009 at 8:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your fine. Take it to an Auto Zone and have the code cleared.
  3. Jul 8, 2009 at 8:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just disconnect the negative battery terminal for about 10 minutes....you'll be fine.
  4. Jul 8, 2009 at 10:31 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Did you use some sensor safe sealant for the deckplate? If not, the fumes from the sealant may have caused the MAF to get a bad reading thus giving you a CEL.
  5. Jul 9, 2009 at 4:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's probably because you disconnected the MAF sensor. You don't have to disconnect it to install the deck plate mod.
    Disconnect the battery for about 10 minutes and see if that helps.
    If that doesn't help, a trip to Autozone/Dealer to pull/clear the code/s.
  6. Jul 9, 2009 at 5:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats exactly it. :)
  7. Jul 10, 2009 at 10:30 PM
    SirVaysa03
    Central Cal
    Yea i disconnected the battery cables for about 15 min and that cleared it up. thanks for the help, i guess i just jumped the gun and got tweaked out when i saw that light stay on, lol. This is a great mod by the way, was suprised to actually feel the difference it made. The help you get on this site is outstanding, thanks guys.
