Deck plate mod worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99kyota2506, Jun 28, 2015.
  1. Jun 28, 2015 at 3:26 PM
    99kyota2506
    99kyota2506 [OP] Well-Known Member
    EO
    1999 Taco/Flatbed
    Get to it later...
    Done a bit of research on this but I see most of them are the 3.4 variants. Anyone do this on the 2.7 3rz and was it worth it? Any noticeable throttle response or HP, gas milage increase/decrease? Thanks in advance!
  2. Jun 28, 2015 at 10:48 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  3. Jun 29, 2015 at 3:41 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    That's about it.
  4. Jun 29, 2015 at 5:38 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Makes a bit of noise, bit better throttle response, maybe a bit of a MPG increase, helps with hills at speed (maybe), but really the biggest thing is the noise. But it's so cheap just go ahead and do it.
  5. Jun 29, 2015 at 7:06 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it has a greater impact when done on the 4 cylinder engines where you can notice it has more throttle response and better gas mileage, with the v6 its more of a "well, I think its better" improvement
  6. Jun 30, 2015 at 7:44 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    I agree. Ive done it on both and it was improvement on both but a lot more on the 2.7l.
  7. Jul 2, 2015 at 10:24 PM
    99kyota2506
    EO
    1999 Taco/Flatbed
    Get to it later...
    So you recommend cutting the back side 90 off then right? Referring to the link that was posted above. Pictures of this?
  8. Jul 2, 2015 at 10:56 PM
    TimPall13
    Tim
    Sandy Oregon
    So here's how I did the one on my 3.4. Same concept just on the 2.7box. The picture actually shows the front lower part cut. And buy the deck plate online cheap. That way you can always screw it back in. I also use some screen door mesh in it to prevent big stuff from going in. If you plan on going in water you also need to seal it but if not you should be okay.
  9. Jul 2, 2015 at 11:52 PM
    99kyota2506
    EO
    1999 Taco/Flatbed
    Get to it later...
    I've seen and read plenty on the above, just not much about cutting the backside. Seems like a better idea with the cooler air drawing.
  10. Jul 2, 2015 at 11:54 PM
    99kyota2506
    EO
    1999 Taco/Flatbed
    Get to it later...
    Nothing to buy this way. Sounds like a better idea too! Just wanted a few pics to make sure I was doing right. Thanks!
  11. Jul 2, 2015 at 11:57 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    All opinions are totally subjective. I have not seen any dyno tests or scan gauge readings to prove any HP or MPG increase. IMO it's a dumb mod and a waste of time.
  12. Jul 3, 2015 at 12:57 AM
    TimPall13
    Tim
    Sandy Oregon
    Yeah that could work. Let us know how it goes and post pictures when done! :)
  13. Jul 4, 2015 at 6:22 AM
    goldentaco03
    Liam
    NJ
    Please post pictures so we have a how to for the 4cyl equivalent!
