Deck Plate Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01YotaTaco, Dec 4, 2009.
  1. Dec 4, 2009 at 10:33 PM
    01YotaTaco
    01YotaTaco [OP] Well-Known Member
    Jordan
    college station
    2001 YotaTaco TRD 4x4
    3.5 inch Revtek lift, Moto metal 951 rims, 33 inch Cooper STT Tires, System with screen 2 10" JL Audio W3V3s and kenwood component speakers.
    Decided to do the deck plate mod on my 01 Taco and i love it. It changed the tone of my truck, made it crazy loud, and gave me wayy better throttle response. Thanks to all you guys that told me about it.
  2. Dec 5, 2009 at 6:39 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    It's one of the best cheap mods you can do to your truck. Glad you like it!
  3. Dec 5, 2009 at 6:52 AM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    my air box has the grooves in it, is it still possible to do the deck plate mod and still be able to seal off the deck plate?
  4. Dec 5, 2009 at 6:55 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    yupp :D
  5. Dec 5, 2009 at 7:06 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    I don't remember where I found it, maybe Yotatech forums or CustomTacos, but there's a write up with pictures of the 2.7L airbox getting deck plate mod'd. Just use sensor safe silcone sealant and you're good, and let it sit overnight before you install the airbox and drive the truck.
  6. Dec 5, 2009 at 8:05 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Very Much so :):)
  7. Dec 5, 2009 at 11:24 AM
    gatorboyy13
    gatorboyy13 Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    I have read alot on this and would like to do it, but i am a noob when it comes to stuff like that do you think it would be easy for me?
  8. Dec 5, 2009 at 11:43 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
  9. Dec 5, 2009 at 1:52 PM
    01YotaTaco
    Jordan
    college station
    Gettin Exhaust monday so it should be real nice after that.
  10. Dec 5, 2009 at 2:51 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    so, it will make the truck louder, correct? seriously thinking about doing this if it's easy enough.
    Just need to find where I can get a deck plate....
  11. Dec 5, 2009 at 3:30 PM
    BG04Taco
    BG04Taco Well-Known Member
    Edmond, OKLA
    04 2.7 SR5 4X4
    ARE Camper, JL Audio, Line-X, Yakima roof rack, odyssey 1500, red line hood struts
    Ive done it and its great I wish I would have had it when I went to colorado for my truck to breath. You can get them at a marine or boat shop I went to a boat store the guy didn't know what I was talking about but then I found one in his inventory.
    Most and I have one that is 4 try to find one that is 3 inch diameter should be good enough.
    :cool:
  12. Dec 5, 2009 at 3:40 PM
    DaytonLax14
    Corey
    Ohio
    not many boat stores in ohio ha ha.
    might have to order one off ebay
  13. Dec 5, 2009 at 8:15 PM
    texasbowhunter
    texasbowhunter Third Coast
    Texas Gulf Coast
    04 Double Cab 4x4 TRD
    Tinted Windows, Moto Metal 955's, Cooper 305/70/16 STT's, Deckplate Mod.,AFE Pro Dry, Toytec Coilovers, 2" AAL, Diff. Drop, Bilstein 5100's On the Corners, Alpine 10" Sub, Alpine 305 Head, Polk Mids
    Do it, you'll love it. It's real easy and there is a ton of info. on how to do it if you have questions.
  14. Dec 6, 2009 at 6:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I did that, but still had more gain with the deck plate.
  15. Dec 6, 2009 at 7:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I got just over 5 hp with the Deck plate. Nothing outside the error margine of the dyno with the elbow mod.
  16. Dec 6, 2009 at 7:43 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    The thing I like about the deck plate is that once you put the plate in, it's back to factory stock. I could see if you just cut a hole in the air box and left it like that not doing it, but going the whole way and installing the deckplate makes the change reversible.
  17. Dec 6, 2009 at 8:36 AM
    DaytonLax14
    Corey
    Ohio
    what should i buy to seal off where the grooves are?
  18. Dec 6, 2009 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When installin gthe deck plate, use a sealant. Run a bead around it, and it should seal everything. I use a "Sensor Safe" Blue RTV.
  19. Dec 6, 2009 at 9:31 PM
    ROTTIRUNNER
    ROTTIRUNNER "Who's got the cookie?"
    Dee or 'D' if ya know me
    Central Arizona
    01-PreRunner w/spunk
    Shell, tint, black stock rims-front-rear bumper.
    I've been meaning to do this I just have to find a boat shop.:rolleyes:
  20. Dec 7, 2009 at 4:14 AM
    DaytonLax14
    Corey
    Ohio
    same here. i will probably be getting one off ebay
