deck plate mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, May 29, 2010.
  1. May 29, 2010 at 9:38 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    so you guys who have done this, how did you cut the hole in the airbox
  2. May 29, 2010 at 9:39 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    hole saw
  3. May 29, 2010 at 10:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A dremmel tool works also...
  4. May 29, 2010 at 10:11 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ok because i have a intake on my truck but pretty sure it wont pass smog because i dont have a carb sticker for it, since i kept all my stock intake pieces i was just going to try this out
  5. May 29, 2010 at 10:23 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    I drew the outline. Drilled small holes in the line. Took a jigsaw and went around. The holes let me start it. Overly complicated? Maybe. Perfect circle. Yes :D
  6. May 30, 2010 at 4:41 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    jigsaw. little tight in a couple places but it worked.
  7. May 30, 2010 at 4:50 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    x2 on the dremel. The perfect circle is just peace of mind I guess, because the deck plate lip is going to cover everything anyway. You could cut out an octogon if you need to. :D
  8. May 30, 2010 at 4:51 PM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    I also used a jigsaw. But I did not cut the hole. Man that would have helped alot.
    I was easy...
    Good luck
  9. May 30, 2010 at 5:25 PM
    mortuusangelus
    mortuusangelus Well-Known Member
    Michael
    Slate Hill, NY
    no truck now :(
    Drill for pilot holes, jigsaw to do the major cutting and a dremel with a grinding wheel to smooth out the hole. :D Oh, and drill again for the 4 holes to mount the plate :D
  10. May 30, 2010 at 10:57 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ok probably gonna do this wednesday, i'll let you all know how it goes im just afraid of the airbox breaking or something
  11. May 31, 2010 at 8:13 AM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    Not much chance in that, that is some thick plastic.
    Actually try to cut the hole as tight as possible... trimming a little is easier than trying to fill in huge gaps :D
  12. May 31, 2010 at 8:48 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    all i used was a drill and a drywall key-hole saw. it took a little while longer then if i had of had a jig-saw but it worked just fine!
  13. May 31, 2010 at 8:53 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    i used a jig-saw too
  14. May 31, 2010 at 9:50 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i just punched it out w/ my fist
  15. May 31, 2010 at 10:55 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ok that sounds good i might just try punching it too
  16. Jun 1, 2010 at 4:18 AM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    You think you're Chuck Norris? Careful, he may be watching. :D
  17. Jun 1, 2010 at 6:06 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Chuck Norris doesn't read books...He stares it down until he gets the information he wants :D
  18. Jun 1, 2010 at 7:45 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Used a dremel tool with a drill bit. Worked real well in my old Tacoma's 3RZ airbox as week as my new one's 5VZ one.
  19. Jun 1, 2010 at 1:13 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Just got my 4" Screw in Deck Plate in the mail :D
  20. Jun 1, 2010 at 4:58 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    you're going to love how it sounds
