deckplate mod advice and detection
Discussion in 'Performance and Tuning' started by ARBman, Jul 1, 2010.
  1. Jul 1, 2010 at 1:50 PM
    ARBman
    ARBman [OP] Well-Known Member
    jobro
    NC
    2000 tacoma
    arb bumper with wench fog lights 3'' inch oldmanemu lift
    from talking to you guys i have decided to do the deckplate mod, first off can i just take the air box out and cut the hole and install the deckplat and keep every thing else the same
  2. Jul 1, 2010 at 1:53 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yes.
  3. Jul 1, 2010 at 1:54 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    yep, unscrew the bolts holding the air box in and just detatch it, take out the air filter and cut the hole, most people do the 4in size which is what i did. Make sure after you cut the hole u wash it out thoroughly to get all the plastic shreds out of the box. Put some sensor safe sealant around the hole and stick the plate in there. Put the box back in and if the check engine light goes on its most likely due to the sealant but mine went away after 30 minutes. goodluck!
  4. Jul 1, 2010 at 1:59 PM
    ARBman
    jobro
    NC
    2000 tacoma
    so i need the screws and the sealant to install the deck plate.and i have the stock papper filter would it help if i put a K&N filter in
  5. Jul 1, 2010 at 2:04 PM
    RPain
    Chandler, Arizona
    I have an AFE pro dry filter and i like it, and all the instructions for the deck plate mod say to screw it in but the sealant holds it in very well so i didn't even do screws, but yes the sealant you can find at any checker/o reilly/auto zone store for under 5 bucks
  6. Jul 1, 2010 at 2:34 PM
    ARBman
    jobro
    NC
    2000 tacoma
    i have the v6 could i fit a 5 inch
  7. Jul 1, 2010 at 2:41 PM
    RPain
    Chandler, Arizona
    i have the v6 as well, you probably could but a 4 inch hole is big enough and you wont see any performance increase between a 4 and 5 inch deck plate
  8. Jul 1, 2010 at 3:45 PM
    ARBman
    jobro
    NC
    2000 tacoma
    ya, so did u take the silencers out of yours.so u leave the center of the deckplate in right
  9. Jul 1, 2010 at 4:02 PM
    RPain
    Chandler, Arizona
    i left the silencers in, and by leaving the center of the deck plate in do u mean leave it screwed in? no you leave it unscrewed so u allow more air in
  10. Jul 1, 2010 at 4:18 PM
    ARBman
    jobro
    NC
    2000 tacoma
    oh ya i see what u mean i just went out to my boat and was looking at one.dose it make alot of nose or dose it sound B*D A*S
  11. Jul 1, 2010 at 4:27 PM
    ARBman
    jobro
    NC
    2000 tacoma
    ya i don't quite under stand what the deckplate dose fill me in
  12. Jul 1, 2010 at 4:40 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    In order to let MORE air into the airbox (provides more power and fuel efficiency) a hole needs to be cut in the filter box to let more air in. The problem with a big hole in the box is that water, dirt and leaves can get in the filter box which will clog and shorten the life of your filter. Also if water gets sucked into your engine, it usually does not end well for your engine. A deck plate ring will let air in through the opening in the custom made hole as well as water and other debris. If you plan off-roading or driving through big puddles or streams, you should fill the hole with the deckplate cap. The cap is water tight and keeps crap out although you'll be back to the original stock airflow and performance. Open for power, closed to keep clean
  13. Jul 1, 2010 at 7:50 PM
    ARBman
    jobro
    NC
    2000 tacoma
    ok went to advanced and got the sealant going to the boat shop to get the deckplate tomo
  14. Jul 1, 2010 at 8:12 PM
    Drewboto
    Drew
    Missouri
    Base model ಠ_à²
    You'll wanna make sure you got a good cutting tool. That plastic box is harder to cut than it looks. Good luck man. Let us know how it goes
  15. Jul 1, 2010 at 8:24 PM
    ARBman
    jobro
    NC
    2000 tacoma
    ya i was thinking along the lines of a sawzol
  16. Jul 1, 2010 at 9:49 PM
    straightaxle
    straightaxle Well-Known Member
    Jordan
    jacksonville, FL
    beast
    alot
    i used a dremal and it wasnt too bad
