Deckplate Mod and code 171
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwilliamson, Apr 11, 2010.
  1. Apr 11, 2010 at 4:01 PM
    bwilliamson
    bwilliamson [OP] Well-Known Member
    Brad
    Magnolia, KY
    I did the deck plate mod today and used sensor safe silicon but when i went to start the truck i got code p0171. Never seen that one before could the deckplate have something to do with it?
  2. Apr 11, 2010 at 4:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    make sure the maf sensor is snapped in all the way. and if you did the install, and started the truck right up........a cel is possible. the silicone needs to dry for a lil while before starting the truck up. disconnect the neg. cable and let it sit for a few minutes to reset the light.
  3. Apr 11, 2010 at 4:08 PM
    bwilliamson
    Brad
    Magnolia, KY
    I dont guess it would hurt anything to clean the maf while im at it would it?
  4. Apr 11, 2010 at 4:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah......but be sure to use some cleaner made for that purpose....no brake cleaner. an electrical contact cleaner will work too.:)
  5. Apr 11, 2010 at 5:33 PM
    bwilliamson
    Brad
    Magnolia, KY
    i just replaced my fuel filter last fall so i dont think i would be that. ive read it could be anything from a vaccum leak to a bad ecm. Real specific huh?
