Deckplate mod done wrong?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomabud, Mar 16, 2010.
  1. Mar 16, 2010 at 9:49 PM
    tacomabud
    tacomabud [OP] Well-Known Member
    Bud
    RI
    04 Black Xtra Cab
    K&N replacement, 4" Deck plate mod, Thrush Welded muffler, 2nd Gen. TRD rims, Herculinered bed, Grey wire mod, OME lift w/ 883 coils and AAL, 265/75/16 BFG A/T, AP 1.5" wheel spacers
    Put a 4" deck plate into the Tacoma today, and when I started the truck up the 'Check Engine' light was on. Overall, the process took 2 days (long story), but I was safe and put a plastic bag over the intake, and I took whatever sensor that's in the intake out. I put a little silicone and paint around the deckplate, but I waited for it to dry for at least 6-7 hours. Any ideas on what it could be? Do I need to reset the computer since the sensor was moved, and if so how?
    I have the stock K&N air filter replacement, but I don't see how that can affect anything. Any suggestions would be appreciated!
  2. Mar 16, 2010 at 9:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    have the code checked, it could just be a coincidence that now you have a different problem
  3. Mar 16, 2010 at 9:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You used Sensor Safe sealant, Correct?
  4. Mar 16, 2010 at 10:00 PM
    tacomabud
    Bud
    RI
    04 Black Xtra Cab
    I used bathroom silicone... Should I remove the silicone I used ASAP and put sensor safe?
  5. Mar 16, 2010 at 10:06 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Where can you buy Sensor Safe Selant?
  6. Mar 16, 2010 at 10:09 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    should be able to find it at most auto parts stores...
    as for the OP...wait another 12-24 hours, disconnect the battery for a couple minutes...and then see if the light returns
  7. Mar 16, 2010 at 10:13 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    X2. Forgot about that. And I think its the negative terminal for 15 min?
  8. Mar 16, 2010 at 10:19 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    probably doesnt even need to be that long
  9. Mar 16, 2010 at 10:19 PM
    tacomabud
    Bud
    RI
    04 Black Xtra Cab
    Is there anyway that I could have damaged the sensor?
    And I'll let it sit for the night and give it a try mid day with the supposed 'warmer' weather.
  10. Mar 16, 2010 at 10:22 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  11. Mar 16, 2010 at 10:27 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    sensor safe doesnt emit the fumes that regular silicone would...the fumes mess with the MAF
  12. Mar 16, 2010 at 10:27 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    That's funny. Just remove your EFI fuse for about 1 min.to reset the CEL. If that doesn't work then try changing the silicone. I think I bought my sensor safe silicone at Walmart. If not, it was at Auto Zone.
  13. Mar 16, 2010 at 10:29 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  14. Mar 16, 2010 at 10:32 PM
    Johnnie
    I.E. SoCal
    Feds
    Yes, your truck will start sneezing and post nasal drip will occur causing the radiator to leak. :D
  15. Mar 16, 2010 at 10:32 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    typically yes...but i suppose its possible to damage it...
    i would venture to guess that if theres no other problems with just a major coincidence...resetting the light via battery or pulling a fuse and letting the truck sit for like 12 hours SHOULD fix the issue
  16. Mar 16, 2010 at 11:11 PM
    john32
    john32 Well-Known Member
    Seaside, Ca
    4x4 Reg cab 2.7L SR5 Manual
    diff breather
    I'm doing the deckplate mod soon if anyone has pics of the finished product i would love to see them. thanks guys
  17. Mar 16, 2010 at 11:39 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you used paint on the intake?
    spray paint?
  18. Mar 16, 2010 at 11:50 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    Mike you bring up a good point...i was focused more on the bathroom silicone...the spray paint could easily mess with the MAF too
  19. Mar 16, 2010 at 11:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, those are hard fumes to lose....
  20. Mar 17, 2010 at 5:44 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i'd say you damaged your sensor. ...not likely to be fumes if you let it dry for 7 hours.
