Deckplate mod done wrong?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomabud, Mar 16, 2010.
  1. Mar 17, 2010 at 7:10 PM
    tacomabud
    tacomabud [OP] Well-Known Member
    Bud
    RI
    04 Black Xtra Cab
    K&N replacement, 4" Deck plate mod, Thrush Welded muffler, 2nd Gen. TRD rims, Herculinered bed, Grey wire mod, OME lift w/ 883 coils and AAL, 265/75/16 BFG A/T, AP 1.5" wheel spacers
    The light was still on this afternoon when I started the truck, but I took the negative terminal off the battery for a few minutes and that got the light to turn off. Thank you all for the help!!!! I was worried that I messed something up big time...
    I didn't take the entire intake off, only the air box (sorry if I miss worded). And I did not use spray paint. I dipped the screw heads into rustoleum before screwing them into the deck plate just to add something a little different. But I let them dry at least 16+ hours before putting it in the truck (one of reasons for taking 2 days).
  2. Mar 18, 2010 at 12:00 PM
    Mskotch
    Mskotch Well-Known Member
    mike
    litchfield,ct
    02 trd v6
    3"toytech lift 285 m/t's w/ toyota tundra wheels grillecraft billet grille 10k HID'S tinted tails fog-light mod westin ultimate series b-bar custom 5 on 5% tint-all around w/ strip debadged ..much more
    To OP..
    as mentioned, it could just be a coincidence that your light popped on. you should know that by unplugging your battery terminal, that may or may not have cured your problem. for example, say you have a faulty O2 senor(bigger issue). by unplugging your batt. terminals, all you are doing is gettin rid of that light temporarily an WILL come back on. if it was something minor, this most likely fixed the issue you were having. but if there is an actual BIGGER problem, your light WAS on for a reason, and you can expect it to come back on.
    good luck. hope that helped.
    mike
  3. Mar 18, 2010 at 9:38 PM
    tacomabud
    Bud
    RI
    04 Black Xtra Cab
    Thank you very much for the information Mike, I will keep an eye on the light as much as possible to make sure nothing is wrong.
  4. Mar 19, 2010 at 5:51 PM
    747
    747 function > form
    1st Gen.
    Mskotch is an alarmist...nothing's wrong dude. Mine did the same thing.
  5. Mar 19, 2010 at 6:30 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
  6. Mar 19, 2010 at 6:34 PM
    747
    747 function > form
    1st Gen.
    [​IMG] Wank!
  7. Mar 21, 2010 at 4:49 PM
    Mskotch
    mike
    litchfield,ct
    02 trd v6
    why thank you sir.
  8. Mar 21, 2010 at 4:55 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    u guys are funny...
    either way, the Check Engine Light comes on for a reason...
    how you wish to treat it is up to you...
