Deckplate mod help!
Discussion in 'Performance and Tuning' started by life11, Apr 27, 2009.
  1. Apr 27, 2009 at 9:22 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    So has anyone done this to a 2nd gen and how did you go about it since there isnt room for a 4" deckplate?
  2. Apr 30, 2009 at 4:52 PM
    T0y0ta05
    T0y0ta05 Well-Known Member
    Pennsylvania
    05 Silver Sport DC Tacoma
    Bone stock other than new floor mats.
    I'm curious about this myself.
  3. Apr 30, 2009 at 5:00 PM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    i did this on my truck and got about 4mpg more than before per gallon not to mention the hp gain.
  4. Apr 30, 2009 at 5:10 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i used just regular clear sillicone i got from ace hardware and mines just fine and its been at least 3 months since i did mine
  5. May 2, 2009 at 9:11 AM
    yotapower10
    yotapower10 Well-Known Member
    Neal
    Virginia
    02 Tacoma SR5 4x4 TRD
    TJM Roo Bar(Front Bumper/Bull Bar), LED Stop/Turn signal, LED undercab/bed lights, Custom Sound System w/ Subwoofer, Spray-In Bed Liner, Deck Plate mod, Black emblems, Black Stock Rims, Custom Fishing Rod Holder
    i just put the deck plate mod on my 02 v6 taco and i love the way it sounds and feels but i didnt read anything about having to put silicone sealer on it until now. With that being said do I need to take it off and put silicone sealer on the back side of the plate? and if i do does it go in between the filter box and the part of the deck plate thats bolted to the box?
  6. May 2, 2009 at 9:18 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    alot of people havent used silicone and havent had any problems. its a good idea to use it tho, cause it'll keep moisture out when the deck plate is screwed in. i'd take the box out and run silicone behind the part that screws to the airbox,screw it back on to the box and let it sit a while. then, you wont have to worry about anything.
  7. May 3, 2009 at 5:06 PM
    yotapower10
    Neal
    Virginia
    ok thanks ill do that as soon as the rain dies down a little bit :( i guess i should have done it to begin with but oh well ill just make sure to dry out my filter real good
  8. May 3, 2009 at 5:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i doubt your filter will be wet at all. i have ran my truck with the deckplate not screwed in for the past 10 months...even offroading, and the only thing that has gotten in the airbox,besides dust, was a lil mud when i hit some good mud pits.
  9. May 3, 2009 at 5:12 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i havent EVER put the cover on my deckplate
    no issues
  10. May 6, 2009 at 6:42 PM
    Rob Lich
    Rob Lich Member
    I followed the deckplate advice from a couple guys on here and just cut a 4" hole (will put in the plate later) and instantly saw a gain in power and better sound in my 01 3.4L! Why spend $150-300 on a CAI?
  11. May 6, 2009 at 9:30 PM
    life11
    life11 [OP] Well-Known Member
    Tempe, AZ
    lifted 04 base V6
    Fabtech 3 inch lift, full magnaflow exhaust, 32 Inch toyo tires, 18 inch rims.
    what do you guys suggest i use to cut the four inch hole with?????
  12. May 6, 2009 at 9:49 PM
    Rob Lich
    Rob Lich Member
    I've been looking around for the best muffler for HP/deep sound and the selection for a 01 3.4L Xtra seems limited. What's a good one?
  13. May 6, 2009 at 10:30 PM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    What is the deckplate mod?
  14. May 7, 2009 at 11:20 AM
    gjbonner
    Guy
    Northern Idaho
    Look at the top of page for "MODS&TUTORIALS" pics and everything. its under "cheap tacoma mods".
    Has anyone done this to a 2nd Gen? and howd ya go about it.
  15. May 7, 2009 at 3:21 PM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It wont work on the second gens...
  16. May 7, 2009 at 3:30 PM
    #36
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2
    best thing for the 2nd gens is removing the secondary filter(even tho thats here and there) and buying a good drop in filter.
  17. May 7, 2009 at 3:32 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No no....I dont recomend removeing the charcoal filter. Neither me OR Gadget found any gains by doing this. None. :(
  18. May 7, 2009 at 3:35 PM
    #38
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just on the v6,right??? like i said before......no dyno or anything, but it "felt" like my 06 prerunner idled better. maybe just placebo affect. on the 4cyl...was that dynoed?? alot have done it on the 4banger and had success.....maybe not dyno or anything.
  19. May 7, 2009 at 3:37 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have been wanting to test the 4 banger, but after seeing nothing happen on the V6, my buddy who has a 4 wont let me try it. :(
  20. May 7, 2009 at 3:38 PM
    #40
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    come on chris.......shoot at him with the air nailer until he surrenders the keys!!! we want info dammit!!!:D:D:D
