Deckplate Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Jan 3, 2009.
  1. Jan 3, 2009 at 5:38 PM
    747 [OP] function > form
    1st Gen.
    I did the airbox (deckplate) mod yesterday, but hesistated to block/remove the larger "silencer" as described on the following webpage: http://www.trdoffroad.com/articles/deckplate/index.php
    Looks like it serves as more than a "silencer"...there's a line-out running from the "silencer" to another engine component.
    Question: Can the "silencer" be removed, and instead run a new (longer) line from the main air intake tube to the unidentified component (i.e., take the "silencer" off, and replace it with a tube)?
    Here's the "silencer" I'm referring to: [​IMG]
  2. Jan 3, 2009 at 5:46 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    I'd just get a T Vaccum connector and connect it to the other hose next to it.
  3. Jan 3, 2009 at 6:01 PM
    1st Gen.
    Any idea on what the "silencer" is...checked the FSM, but couldn't find anything.
  4. Jan 3, 2009 at 6:04 PM
    Cobra69
    It quiets down the huge sucking sound you hear when you step on the throttle.
  5. Jan 3, 2009 at 6:05 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i blocked both of them off and it dont do anything just makes it louder
  6. Jan 3, 2009 at 6:07 PM
    Cobra69
    yup, i had the K&N intake on my truck ............took it off cuase i hated the throttle noise everytime I took off.
  7. Jan 12, 2009 at 4:52 PM
    bsmith4293
    bsmith4293 bnasty
    So what did you do with the hose coming from the silencer?? You just cap it off or something??
  8. Jan 12, 2009 at 4:57 PM
    Cobra69
    added a T connector and connected the two lines.
  9. Jan 12, 2009 at 5:06 PM
    bsmith4293
    bsmith4293 bnasty
    Oh. Sorry I must have missed that LOL. Do you know what the hose line is for??
  10. Jan 12, 2009 at 5:15 PM
    Cobra69
    I think it just a vaccum line.
  11. Jan 12, 2009 at 5:20 PM
    bsmith4293
    bsmith4293 bnasty
    OK. Thanks for your help buddy : )
  12. Jan 12, 2009 at 5:50 PM
    Cobra69
    NP........sorry i couldn't give you a definate answer I really not sure what they go to. I can tell you I never had any problems when I T'd mine off.
  13. Jan 12, 2009 at 6:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    those are actually for cooling valves down i think.
  14. Jan 13, 2009 at 9:13 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    Hmmm, sounds important, maybe tie it in to the main line by bushing down the (original) hole for the silencer?
  15. Jan 13, 2009 at 2:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that would work....or even a "t" fitting will suffice.
