Deckplate = Worse MPG?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatrapper, Oct 1, 2011.
  1. Oct 1, 2011 at 8:01 AM
    gatrapper
    gatrapper [OP] Well-Known Member
    CJ
    Senoia, Georgia
    1998 SR5 4x4
    I have read on a few other places that the deckplate mod will lower your MPG. They said that the truck intakes hotter air, which lowers the MPG.
    Thoughts on what was said above?
    Also any other input of the positives and negatives of the deckplate will be appreciated.
  2. Oct 1, 2011 at 8:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Not for me. After my new exhaust and deckplate i gained about 1.5mpg
  3. Oct 1, 2011 at 8:21 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i have heard eveyone gains from it cause the air from outside gets forced into it
  4. Oct 1, 2011 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I saw a gian on my first gen. That being said, Hotter air = better mpg. Hotter air has less O2 density, thus requiring less fuel to achieve an 14.7-1 AF ratio.....
  5. Oct 1, 2011 at 8:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :ohsnap:
  6. Oct 1, 2011 at 9:39 AM
    scalfee90
    scalfee90 Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    It actually causes mine to have cold start issues and my mpg tends to suck when its out. Mines a V6.
  7. Oct 1, 2011 at 12:19 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I noticed a decrease in mileage by about 1.5. :notsure: But I did have a pretty nasty air filter. I changed that and I'm testing it with and without the deckplate now....
  8. Oct 2, 2011 at 12:29 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That kinka flies in tha face of the supposed advantages of cold air intakes doesn't it?
    I've not been able to see a difference between having the plate off or on. I monitor my fuel mileage pretty closely with my scangauge.
  9. Oct 2, 2011 at 12:32 AM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    havent tested a full tank yet so ican get a true reading, but i did however notice a power difference, so if i lose maybe 1 mpg, IMO, its worth it. but i doubt i will
  10. Oct 2, 2011 at 5:48 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    OP, if you already did the deckplate mod and don't like the mod affecting you mpg leave the cover on. otherwise, if you like the little power gain then it is worth that mpg drop.
  11. Oct 2, 2011 at 8:10 AM
    asmoran
    asmoran Member
    No, not really. Higher density means more fuel and more power. People install a CAI for power, not for fuel economy.
  12. Oct 2, 2011 at 1:25 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    IMO, messing with the intake on your truck will degrease MPG's. Its designed from the factory to be efficient. Save maybe the elbow mod.
    I put on a CAI, and lost about 2mpg w/ little to no improvement in power. I put the stock intake back on..
  13. Oct 2, 2011 at 1:33 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    It flies in the face of the incorrect assumption that a cold air intake makes better mpg. People that are looking for max mpg create warm air intakes off of the exhaust.
  14. Oct 2, 2011 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Some CAI manufacturers (and their retailers) do make a clam of higher MPGs.
    With the installation of an aFe Cold Air Intake Magnum Force Stage 1, you are basically removing the most restrictive part of the stock air intake system. You will feel an immediate improvement in acceleration and throttle response. Every vehicle responds differently but you are guaranteed to improve the fuel economy and enhance performance.
    http://4wheelonline.com/AFE_Cold_Air_Intakes.58741
  15. Oct 2, 2011 at 9:01 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    i've been running the deckplate mod and an AFE pro-dry air filter for about a year now and still get 19-20mpg on the freeway. same as what i got before the mods. no difference in mpg for me, but i do like the sound :)
  16. Oct 2, 2011 at 9:35 PM
    worthywads
    The most restrictive part of the stock air intake system is the throttle plate at anything less than wide open throttle. At part throttle a restricted air intake has zero effect, it's still less restricting than the throttle plate that is intentionally holding the engine back from uncontrolled acceleration.
