Decrease in turning radius after putting on a lift kit
Discussion in 'Suspension' started by cole northern va, Nov 30, 2011.
  1. Nov 30, 2011 at 4:45 PM
    cole northern va
    cole northern va [OP] Member
    Cole
    Northern VA
    2011 Toyota Tacoma 4 Door Black 4X4
    Fabtech 6 inch suspension lift, 35 inch Nitto Trailgrapplers, Black Rims Alpine Stereo, Undercover bed cover, Tinted Windows, Westin Chrome Push Bar
    I recently got a 6 inch suspension lift kit installed on my 2011 Tacoma. The lift kit is by Fabtech and from what I have read the kit is supposed to be pretty good. I also have 35 inch Nitto Trailgrapplers on the truck as well. There is noticable difference in turning radius now and when I turn the wheel fully to the left or right, there is slight rubbing. The noise is not too bad however I am wondering with a 6 inch lift and 35 inch tires should there be any rubbing at all and should the turning radius be reduced a lot. I am going back in this week for any final adjustments and to make sure everything is still tight after the first 500-1000 "break in" period with the new lift but was wondering if anyone is or has experienced the same issues.
  2. Nov 30, 2011 at 4:49 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I think I've heard that 6" lifts include steering stops, in which case yes your turning radius is larger.
    Rubbing should be fixed up by trimming and/or different wheel offset.
    Some tires are so big they're going to rub no matter what.
  3. Nov 30, 2011 at 4:49 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Yes and yes , trim the fenders
  4. Nov 30, 2011 at 4:49 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    I know you'll lose ur turning radius . Rubbing depends on ur back spacing .
  5. Dec 1, 2011 at 3:44 AM
    cole northern va
    Cole
    Northern VA
    Thanks everyone for the replies. If I am not mistaken, the offset was supposed to be zero (0), which the installer told me there would be no rubbing. Its not really to big of an issue but it would be great not to have the rubbing. In either case, I really like the look and feel of the truck. I am not sure if you saw the photos on my profile. I am new to the site and still trying to work out the kinks with my profile.
    One last question - for now - Does the picture of my truck show up on the profile when I post a question and if not does anyone know how to make that happen. ???
    Thanks
  6. Dec 1, 2011 at 7:52 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
  7. Dec 1, 2011 at 1:55 PM
    cole northern va
    Cole
    Northern VA
    Thanks BVCOTaco. Great instructions.
