Decreasing Turn Radius Thought Experiment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by viperstd, Dec 9, 2010.
  1. Dec 9, 2010 at 6:38 AM
    viperstd
    viperstd [OP] Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Since my last thread started a bit of an expected shit storm... let's see if I can start another one.
    Right off the bat let me clarify: This is a mental exercise only! If your only comment is:
    • it can't be done
    • too expensive
    • buy a different truck
    • un-possible
    • x2
    • x1,000
    Please don't bother responding. This thread is a place for gear heads to discuss what it would take to accomplish the goal.
    The challenge: Modifications required to decrease the 22' (6.7 m) turn radius of the doublecab long bed, 2nd gen Tacoma.
    e.g.
    Piecut frame for wheel clearance.
    ok now I have frame clearance but not the rack travel to use it.
    Cut more teeth in the rack.
    ok.. what is going to drive the pinion to turn the rack?
    Longer travel hydraulic rack pump.
    Remove/relocate steering stops
    etc.
    Cheers 2nd-gen gear heads!
    :cheers:
  2. Dec 9, 2010 at 6:44 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I think the most logical thing to do would be not touch the front end at all. If I had more money than brains, I would do a rear steer set-up.......................or buy another truck
  3. Dec 9, 2010 at 6:46 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Rear steering :confused:.
  4. Dec 9, 2010 at 6:46 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    didn't you just answer your own question?
  5. Dec 9, 2010 at 6:47 AM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    x2
  6. Dec 9, 2010 at 6:51 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha ha good one...
    I think wheel spacers plus shave off the stops would give you slightly smaller radius but buying new truck will accomplish even more :D
    Now if you had only A-trac you probably could have turned in a spot just by pressing magical button;).
  7. Dec 9, 2010 at 6:52 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Something like the Denali. Makes for a broken rear axle so all those bearings and joints you have in your front end, you now have in the back as well. Double the maintenance, expensive as hell I'm sure, but probably the most effective way to do this. Denali's only have the rear steer when you're under a certain speed. There was an old Accord model that had this also.
    Minor improvements can be had by changing your alignment. I'm thinking something more similar to a flat track car but that wouldn't be good for normal driving.
    Easiest way, turn the wheel and stomp the skinny pedel and wait for the back end to come around.
  8. Dec 9, 2010 at 6:53 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    WOW, heck of an idea..but not going to happen on a 4*4 IMHO.
  9. Dec 9, 2010 at 6:54 AM
    viperstd
    Maryland
    I VERY SPECIFICALLY asked people to not chime in with
    "x2"
    "buy another truck"
    type feedback... :deadhorse:
    Rear-steer, while a sound suggestion, is not in the spirit of the original question.
    I didn't answer my own question, I was merely attempting to get everyone's creative juices flowing.
    :boink:
  10. Dec 9, 2010 at 6:56 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    How does rear steer not fit "in the spirit of the original question"?
  11. Dec 9, 2010 at 6:58 AM
    viperstd
    Maryland
    Does this truck have mechanical steering stops, or are they internal to the pump? When I turn the wheel it feels like I am hitting a mechanical (tab-type) stop. Would relocating this free up a few degrees of wheel toe?
  12. Dec 9, 2010 at 6:59 AM
    viperstd
    Maryland
    Because I wasn't thinking along those lines when I wrote the question :D!
  13. Dec 9, 2010 at 7:04 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Just look under the front of the truck at the wheel. You'll see the flat metal stop.
  14. Dec 9, 2010 at 7:05 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Add a rear diff disconnect so you can do front digs.
    I know, I know, "not in the spirit...."
  15. Dec 9, 2010 at 7:06 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Ah, change the rules as we go I see. Will we be making a wheel rounder next?
  16. Dec 9, 2010 at 7:08 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Any modification, you do in order to accomplish your goal will cost a lot of money.
    You have to ask yourself is this really worth it?
  17. Dec 9, 2010 at 7:12 AM
    viperstd
    Maryland
    is a "wheel rounder" like a "finger-longer"?
  18. Dec 9, 2010 at 7:13 AM
    Pugga
    Massachusetts
    F-150 Mod
    I'm gathering the OP has no intention of actually doing this. This is just a 'what if'.
    If your front wheels turn over too far you'll just plow with the front tires with a rear wheel drive truck which is why rear steer is an effective solution. It reduces turning radius while not overextending the angles on your front end.
  19. Dec 9, 2010 at 7:14 AM
    viperstd
    Maryland
    Is it worth it? No... Is it a fun mental-exercise? For me, yes it is.
  20. Dec 9, 2010 at 7:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Cut the rear suspension, and re mount it forward about 20".
