Dedicated Winter Tire / Rim Set-Ups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alan_G_TRD, Oct 31, 2016.
  1. Dec 5, 2016 at 3:31 PM
    #101
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    This will be my 4th winter with this specific set and I anticipate zero issues. I just wish they looked better on the truck! They looked fine on my old once since they were the stock wheels.
    I run without sensors, but I like living on the edge.
  2. Dec 7, 2016 at 7:34 AM
    #102
    mr_ash
    mr_ash Well-Known Member
    Ash
    Colorful Colorado
    2016 DCSB TRD OR
    Not until today! They work great. Drove through 6-8" of dry snow as well as 1-2" hard pack and truck handled just fine (I have studs on mine).
    This is just one data point but so far I'd recommend them. Snow clears well from them...but, it is only 12F, so it is dry snow. I'll try and report back throughout the winter/spring.
  3. Dec 7, 2016 at 9:09 AM
    #103
    GREXK
    GREXK Well-Known Member
    CT
    2018 TRD OR DCSB MANUAL
    Am I doing this right?
  4. Dec 7, 2016 at 12:40 PM
    #104
    Mtneer
    Mtneer Active Member
    I ran those tires on my 2002 Tacoma DC and my 06 Tundra, they did great in all types of driving in WV, I ran them year round and got around 30,000 miles out of a set, with a set studded you should be able to go on icy roads just fine as well as snow covered roads, only negative is they seem to need balanced more than other brands, good tire for the money.
  5. Dec 7, 2016 at 7:58 PM
    #105
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I see WV in there, and noticed the username, but be and eer's fan?!?!?!
  6. Dec 7, 2016 at 8:46 PM
    #106
    Mtneer
    Yes I live outside of Fairmont and grew up near Bluefield, went to school and my wife works at WVU, been driving Toyotas since 1996, one Tundra(06 AC), 4 Tacomas(96 reg cab, 02 DC, 09 DCLB, 16 DCLB).
    ecotecin[QUOTED] likes this.
  7. Feb 5, 2017 at 10:54 PM
    #107
    GotRice?
    GotRice? Well-Known Member
    Edward
    Edmonton AB
    '16 White Tacoma LTD
    I run this setup and I will NEVER go back to regular winter tires. Ever.
    My wife has Hakka 7 studded tires on her SUV and with AWD, it handles ridiculously well when driving in the Canadian Rockies.
    You don't know what you're missing until you drive with these tires.
    RichVT[QUOTED] likes this.
  8. Feb 6, 2017 at 3:30 AM
    #108
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Just going to use my methodLv's and purchased Hankook directional snows20170116_124055.jpg
  9. Feb 6, 2017 at 5:23 PM
    #109
    49°NRTH
    49°NRTH Well-Known Member
    2017 DCSB OR
    Also running the Nokian Hakkepelita SUV7 and I'll echo the comments above, after using them it'd be hard to go back to regular tires in the winter months
    I've got them studded and mounted on a set of silver steelies along with TPMS sensors
  10. Feb 6, 2017 at 6:27 PM
    #110
    TRD-OffRoad_Ben
    TRD-OffRoad_Ben Well-Known Member
    Ben
    2016 TRD OffRoad LB
    I'm running stock TRD OR rims and just upgraded to 265/75/R16 KO2 tires and am super happy with how they perform in snow. We got 8" last night!
    I feel like the KO2s will work great as a year round tire in both winter and summer driving conditions.
    When the weather gets better maybe I'll upgrade my rims.
  11. Feb 6, 2017 at 8:00 PM
    #111
    TRDwolverine
    TRDwolverine Well-Known Member
    '16 Quicksand TRD OR DCSB MT
    I'm running Blizzak DM-V2 in 245/75 R16 on a set of TRD Off Road rims. Went slightly taller/narrower than stock off road tires. They've been great in the lake effect snow we get here in West Michigan.
    onesixonetwo likes this.
  12. Feb 6, 2017 at 8:06 PM
    #112
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When you switch the Stock Wheels and Tires back on will the Truck recognize the Original Sensors?
  13. Feb 6, 2017 at 10:19 PM
    #113
    Mtneer
    In my case, my tire shop copied the ID numbers off my OEM sensors and programmed them into the sensors he put in my steel wheels, so I'm pretty sure it won't require reprogramming the OEM ones, the winter wheel are copies of the summer ones.
    shakerhood[QUOTED] likes this.
  14. Feb 7, 2017 at 3:29 AM
    #114
    49°NRTH
    2017 DCSB OR
    I bought a ATEQ Quickset tool which will 'read' the stock wheel sensor IDs off the ECU and had the dealership record the steel wheels new sensor IDs, which were negotiated when I purchased the truck, then wrote those into the Quickset tool. Then it's just a matter of pushing the summer/winter button when swapping wheels.
    This way I can just swap them over myself and not have to worry about scheduling and paying for the reprogramming each season.
    Quickset
  15. Feb 7, 2017 at 4:34 AM
    #115
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    I picked up a set of used Firestone Winterforce LTs with studs on factory steel wheels for $600 on craigslist. They were already painted MGM to match my truck :thumbsup:
    Only downside is they are LOUD
  16. Feb 7, 2017 at 2:42 PM
    #116
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I'm really happy with these tires (Nokian Hakkepelita 8 studded). A little more noise than an unstudded tire but no other downsides that I can detect. I find myself using 4WD a lot less because I just don't need it with these tires.
    If your are looking for the ultimate winter tire, these should be on your short list.
  17. Oct 2, 2018 at 8:34 AM
    #117
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    I put Blizzaks on my stock wheels at stock size. They work awesome in snow, slush, rain, and on dry!
    Bought some method roost wheels in bronze and put my stock tires on those.
