Deep vibration from Passenger side in the engine bay.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jadesparrow, Jan 17, 2018.
  1. Jan 17, 2018 at 3:04 PM
    jadesparrow
    jadesparrow [OP] Well-Known Member
    Tim
    San Angelo, TX
    2011 White Tacoma 4.0 V6 4wd
    3" lift, ARB bumper
    I noticed what sounds and feels like a deep vibration kind of resonance coming from the passenger side of the engine bay. My first thought is an exhaust leak but curious what y'all have encountered. It only happens when the engine is around 900-1200 rpms and is louder when accelerating but is there while coasting and idling as well. Any thoughts or has anyone encountered this as well?
  2. Jan 17, 2018 at 3:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    exhaust heat shield. Go through (when cold) and tighten the mounting bolts.
  3. Jan 17, 2018 at 3:15 PM
    jadesparrow
    Tim
    San Angelo, TX
    3" lift, ARB bumper
    I'll give that a shot
  4. Jan 17, 2018 at 7:39 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If it's not the heat shields, check the air intake where it goes into the fender.
    Remove the 2 bolts and hose clamp, when you take it out of the fender you'll see the cheap foam gasket they use.
    While it's off, take it for a ride and see if the noise is gone.
    This is what I found on my truck your results may vary.
