Deer+ 95 Tacoma= signal light problem
Discussion in 'Technical Chat' started by doninva, Jan 19, 2011.
  1. Jan 19, 2011 at 3:31 PM
    doninva
    doninva [OP] Member
    Don
    Penhook, Virginia
    97 standard cab-straight drive with 276,000 m
    My boy was coming home from work two nights ago and a deer decided to play chicken. The deer lost. It hit the front right at the driver side headlight and some how hit the driver side door right at the hinge. There is little damage. The plastic adjustment for the headlight at the top broke and there was a little place at the door. The truck has a brush guard. The problem is the driver side signal lights. When you turn them on, the back blinks real fast but the front bottom and the bulb at the side marker don't work. We checked the bottom bulb and replaced the one at the marker lights. I checked all the wiring at the lights and all fuses in the truck. Any help would be greatly appreciated. Don
  2. Jan 19, 2011 at 3:32 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    pics yo.
  3. Jan 23, 2011 at 9:24 AM
    doninva
    doninva [OP] Member
    Don
    Penhook, Virginia
    Well, small thing will get you sometimes. My boy changed the bulb at the front, that looked good, problem solved. Don
