Deer hunting BS thread
Discussion in 'Guns & Hunting' started by buzzard1992, Dec 8, 2011.
  1. Feb 14, 2025 at 7:31 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    ChatGPT suggested these:
    If you’re new to deer hunting with a crossbow, you’ll want one that balances power, accuracy, and ease of use. Here are a few solid beginner options:
    1. Barnett Whitetail Hunter STR
    • Speed: ~375 FPS
    • Draw Weight: 187 lbs
    • Pros: Lightweight, affordable, comes ready to shoot with a scope and bolts
    • Cons: Slightly noisy, but can be dampened
    2. CenterPoint Sniper 370
    • Speed: ~370 FPS
    • Draw Weight: 185 lbs
    • Pros: Adjustable stock, good accuracy, budget-friendly
    • Cons: Heavier than some models
    3. Killer Instinct Ripper 415
    • Speed: ~415 FPS
    • Draw Weight: 200 lbs
    • Pros: High speed for the price, adjustable stock, good trigger
    • Cons: Higher draw weight can make cocking harder
    4. Wicked Ridge Rampage 360
    • Speed: ~360 FPS
    • Draw Weight: 175 lbs
    • Pros: Made by TenPoint (quality brand), comes with ACUdraw cocking system for easy use
    • Cons: Slightly lower speed than others
    5. Bear X Intense CD
    • Speed: ~400 FPS
    • Pros: Compact design, great for tree stands or blinds, fast for the price
    • Cons: Included scope isn’t the best
    Key Features to Look for in a Beginner Crossbow:
    • Speed (FPS): 300+ FPS is good for deer; 350+ FPS gives better range and power.
    • Draw Weight: 150-200 lbs (too high can be difficult to cock without a crank).
    • Ease of Cocking: Look for cranking devices or rope cockers to make it easier.
    • Included Accessories: Some crossbows come as a package (scope, bolts, quiver, etc.).
    • Durability & Weight: Lighter crossbows are easier to carry but may have more recoil.
    If you’re on a budget, the Barnett Whitetail Hunter STR or CenterPoint Sniper 370 are great starters. If you want more power and are willing to spend a little more, the Killer Instinct Ripper 415 is a solid choice.
  2. Feb 14, 2025 at 7:46 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Any of the ones mentioned above are capable of killing a deer. I would suggest that you go online and research some of the reviews for different manufacturers. Several companies have had numerous issues with their crossbows. I personally own a Ravin and a Ten Point and both companies have had their share of issues. Based on what I know now after talking to local bow shops and the people who work on and repair them, if I was to buy a new one today it would be a Mission or Excalibur. The guys tell me that they very seldom see those 2 brands coming in for repairs.
  3. Feb 14, 2025 at 7:48 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    No kidding!:spending:
    Then he has to decide recurve or compound. Both have advantages and disadvantages.
    Look used as well as people are always getting newer.
    I have a Tenpoint Venom that's 10 years old.
    It was pricy back then. So far it has performed flawlessly. Cables are holding up well.
    I only replaced the Accudraw string this past Fall as it was starting to fray..
    Heavy (more so with a monopod attached) (need it now with my crappy shoulders), clunky, and noisy, but they kill well.
  4. Feb 14, 2025 at 7:49 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly-09 Primo XL custom cover, D-plates, divider, raised grates
    i have had my "starter" 10 pt for 25 years now
  5. Feb 14, 2025 at 7:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    We have a parker 150lb draw. I killed my buck this season. I bought my wife a new 10pt crossbow and she missed a doe with it:annoyed:
  6. Feb 14, 2025 at 8:16 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @buckhuntin-tacoma , to be completely honest. Before my back got screwed up, I carried a full size 1911 with an extra magazine or two.o_O
  7. Feb 14, 2025 at 8:20 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    I carried one for years as well. I swap between my shield 9mm and my xdm 10mm depending on the day
  8. Feb 14, 2025 at 8:27 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Check out Wicked Ridge while yer looking.
  9. Feb 14, 2025 at 8:28 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I just got my first 1911, waiting on decent weather to shoot it.
  10. Feb 14, 2025 at 8:41 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    My wife has killed a lot with her $189 Barnett, I've killed one with my $500 Carbon Express :anonymous:
  11. Feb 14, 2025 at 8:47 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Hunter>weapon
    :rolleyes:
    wilcam47, 1buzzbait, Z7Xtreme and 2 others like this.
  12. Feb 14, 2025 at 8:47 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :anonymous:
  13. Feb 14, 2025 at 8:47 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :anonymous::anonymous:
  14. Feb 14, 2025 at 9:13 AM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    The wife has a Excalibur Assassin 360 and I switched to a Mission Sub1 lite this year. I would recommend either. Watch the weight of bolt and broadheads you use. Your going to want to go heavier than they call for to save yourself problems with the limbs. I’d be careful buying anything used because of the lifetime warranty deal.
  15. Feb 14, 2025 at 10:19 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    What if its more like lucky>weapon>hunter :notsure:
  16. Feb 14, 2025 at 10:32 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :bowdown:
  17. Feb 14, 2025 at 11:01 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    My dude dropping wisdom bombs over here :fistbump::fistbump::fistbump:
  18. Feb 14, 2025 at 11:02 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :nuclear:
    :nuclear::nuclear:
    :nuclear::nuclear::nuclear:
    :nuclear::nuclear:
    :nuclear:
  19. Feb 14, 2025 at 12:30 PM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Bought a Ravin R15 used (from Michigan) worked flawlessly for several years until the strap ripped when cocking it. Was covered under warranty and cost me ~ $75 shipping to mfg. both ways. Spent $1500 on it and it shot wicked fast (could never see the bolt in flight!!). Gave it to my son since I quit bow hunting after crippling one (never found it) 2 years ago.
    Would I buy another one??? YES!!!
    Wish I could still use my compound bow - Mathews DXT - but torn rotator cuff AND biceps stopped that fun hunting!!!
  20. Feb 14, 2025 at 3:38 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Well please extrapolate on this, and tell us what pistol you purchased. I'm going to guess a Wilson Combat, because I don't see you buying a cheap pistol. And for a classic TW response.
    :worthless:
