Deer hunting BS thread
Discussion in 'Guns & Hunting' started by buzzard1992, Dec 8, 2011.
  1. Jan 14, 2024 at 7:00 AM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
  2. Jan 14, 2024 at 7:15 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    Go for it!!
    I bought a CVA on sale at Walmart years ago at lunch time, used it that afternoon and killed a fat doe right under my stand, drug her out, and the next morning, same stand, a big coyote scent trailed her right to the bottom of my tree, he took a dirt nap!! :thumbsup:
  3. Jan 14, 2024 at 8:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yes they are good!
  4. Jan 14, 2024 at 8:02 AM
    wilcam47
    Will
    Bourbon state
    If you use pellets get triple 7. Is it 209 primer? I use loose powder. 100-110grains.
    I wipe out barrel after 2-3 shots. Deep clean after done shooting for the day. Bore butter after its cleaned and dry. You dont need a lot of bore butter. A small tube will last a long time
  5. Jan 14, 2024 at 9:24 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yeah 209 primers, comes with a plug for pellets but loose powder plug is like $35-40. Blackhorn 209 looks to be $20 per pound so the plug would pay for itself quick (looks like 80 gr by weight is roughly 100 gr by volume... 7000 gr in a pound so ~90 loads for $20. Also seems like it's a really advanced/clean powder
  6. Jan 14, 2024 at 10:20 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    I use blackhorn 209 90 grain equivalent with a scorpion 300gr sabot love it
  7. Jan 14, 2024 at 11:45 AM
    yota243
    E.J.
    north Alabama
    The eventual plan would be casting something like these at .458 (because I have a 45-70 and the mold could pull double duty one day) https://arsenalmolds.com/products?product_id=201
    Then this...
    https://harvestermuzzleloading.com/...cts/crushed-rib-high-pressure-sabots-50-cal-4
    Sabots are $.20 a piece and wheel weights would be free-basically free.
    I honestly feel like I can make sabots sleeves from HDPE with a little practice, since I have a good bit of experience with kydex... And my projectiles would cost $.00. man I'm thrifty and it shows lol
  8. Jan 14, 2024 at 11:46 AM
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    What he said ^..... Clean everything out... Barrel, plug and firing pin... Residue gets gunked fast!
  9. Jan 14, 2024 at 11:54 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    This. I don't know about the White Hot powder, but the Blackhorn is top notch stuff. I've never shot enough to foul the barrel nor has not cleaning it at the range ever affected accuracy, and I've let it set two or three days without cleaning with no ill effect. The only problem is finding it anymore.
  10. Jan 14, 2024 at 11:58 AM
    yota243
    E.J.
    north Alabama
    I watched a video of a guy who let it set for 1,3 and 7 days and it was still ringing the gong at 100 yards. Keep your power dry, flash in the pan l, going off half cocked and or any other black powder related proverbs inserted here
  11. Jan 14, 2024 at 12:39 PM
    wilcam47
    Will
    Bourbon state
    I just tell myself its all corrosive, that way i dont forget to clean it.
  12. Jan 14, 2024 at 4:07 PM
    Gooch123
    Gooch123 Well-Known Member
    Greg
    Southern Indiana
    23 sr5 all black
  13. Jan 14, 2024 at 5:00 PM
    dewayne
    dewayne Simply Southern.
    Dwayne
    Shenadoah Valley,Virginia
    2015 tacoma AC mettalic grey
    265/75r16 KO2 5100 level at1,75,Icon 3 leaf addaleaf pac,amp,speakers,holster,black out badges
    pellets are the way to go for ease of use. Ive used Pyrodex and 777 pellets and never had an issue.260gr. Winchester platnium tip(aka black talon)with 2 Pyrodex pellets.
  14. Jan 14, 2024 at 8:13 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    My Knight Big Horn absolutely loves pellets. I use Pyrodex behind a Hornady SST 250 or 300 gr low drag sabot. Deadly accurate. I see no reason to switch.
  15. Jan 15, 2024 at 6:33 AM
    dewayne
    Dwayne
    same reason i still use Pyrodex. got a VERY accurate set up using 2 50gr pellets in mine. i dont even change primer brands. :thumbsup:
  16. Jan 15, 2024 at 6:36 AM
    dewayne
    Dwayne
  17. Jan 15, 2024 at 9:03 AM
    wilcam47
    Will
    Bourbon state
    @1buzzbait
  18. Jan 15, 2024 at 9:44 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    prolly only 2 hrs away....
  19. Jan 15, 2024 at 10:50 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Made some euro mount plaques, in preparation for my deer skull to come back home :sawzall:
    lynyrd3, dewayne, Z7Xtreme and 10 others like this.
  20. Jan 15, 2024 at 5:12 PM
    Off Topic Guy
    He’s finally home!
    lynyrd3, CountryDan, dewayne and 9 others like this.
