Deer protection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Woods and Water, Jul 17, 2014.
  1. Nov 9, 2014 at 11:10 AM
    #41
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    #41
  2. Nov 9, 2014 at 11:11 AM
    #42
    Idaho
    Idaho Well-Known Member
    North Carolina
    The area I am in here in NC has quite a lot of deer as well and I will almost always see one on my way home from work during the 30 mile drive if I am working nights.
    I'd also suggest getting a LED bar or a larger light source as the Soltek's I had on my last truck paid dividends plenty of times when I was able to see deer 1/2 mile up the road so I had time to slow down.
    Granted this only works if you are planning to drive in areas of little to no traffic.
  3. Nov 9, 2014 at 11:13 AM
    #43
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Perhaps, with some of the advice given here, we should be investing in bigger, louder horns, and auto dimmers for the headlights.
    in fact avoidance technique would suggest a loud horn, running off an interval timer, say every 15-30 seconds, and drive with your headlights off would be the ultimate best practice for driving at night when there is wildlife around.
  4. Nov 9, 2014 at 11:16 AM
    #44
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Can't be dim, it'll make them even more attracted if the light is animated.. What about infrared windshields? Then you can drive lights out all the time and be safe from deer AND zombies.
    Can you make a deer whistle but car size? With infrared? Then you'd just need to bolt on a seat and some tires and voila. Completely cloaked.
  5. Nov 9, 2014 at 11:25 AM
    #45
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Is that what my scoop is for?
  6. Nov 9, 2014 at 11:26 AM
    #46
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I'd like a train horn. Bout shit myself when a guy hit his at an asshole in front of us.
  7. Nov 9, 2014 at 11:26 AM
    #47
    T4RFTMFW
    No it's still totally useless. :D
    SR5 FTMFW
  8. Nov 9, 2014 at 11:28 AM
    #48
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    When is a vendor going to make it useful?
  9. Nov 9, 2014 at 11:28 AM
    #49
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    There was a woman killed by a deer thrown through the windshield in my hometown years ago. The deer was hit by another vehicle on the other side of a divided highway and thrown clear across a 40' median (I'm not exaggerating- 40 feet!) before hitting her.
    I've employed this strategy for years, especially at night.
  10. Nov 9, 2014 at 11:31 AM
    #50
    T4RFTMFW
    Just slam on your brakes, then before you hit the deer, let go of the brake pedal while flashing your high beams.
  11. Nov 9, 2014 at 11:32 AM
    #51
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Works 4 me
  12. Nov 9, 2014 at 11:35 AM
    #52
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    some of the bus drivers at the company i worked for swore by the whistles they said the whistles would make the deer lift thier heads and the head lights would catch thier eyes at night
  13. Nov 9, 2014 at 11:39 AM
    #53
    T4RFTMFW
    Deer lift their heads when alerted, a car driving up to them at 40 MPH makes them lift their head as easy as a whistle on your bumper does. I can fart on a hillside 250 yards from a deer, and they'll lift their head.
    Placebo effect is always cheap, because it has no value.
  14. Nov 9, 2014 at 11:59 AM
    #54
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    The deer around here (and there's a lot) don't care about horns, lights, whistles or any other doodad you try to use to scare them. They're so used to traffic and humans they just don't care. Best advise is if you know there's deer around where you're driving slow down, keep an eye on both sides of the road and get a good set of driving/ foglights to aluminate the sides and further down the road more.
  15. Nov 9, 2014 at 12:04 PM
    #55
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
  16. Nov 9, 2014 at 4:41 PM
    #56
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yeesh, you guys are busting my chops pretty good. I'm happy you had some fun.
  17. Nov 9, 2014 at 5:26 PM
    #57
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Tried to find info on 'deer diving into light' as i've never observed that. Could be just because i've never observed that, that doesn't mean it doesn't occur.
    Here's what I found so far. This is consistent with my experience.
    "Q: Why do deer get transfixed by car headlights and just stand there in harm's way?
    "Deer are crepuscular," said David Yancy, a deer biologist with the Kentucky Department of Fish and Wildlife Resources.
    Their activity peaks within an hour or so on either side of sunrise and sunset, so their vision is optimized for very low light. When a headlight beam strikes eyes that are fully dilated to capture as much light as possible, deer cannot see at all, and they freeze until the eyes can adjust.
    "They don't know what to do, so they do nothing," Yancy suggested.
    Continuing research at the University of Georgia on whitetail deer vision suggests that by human standards, deer are legally blind. A researcher interviewed in the September/October issue of Arkansas Wildlife estimated their vision at 20/200: Where a person with normal eyesight can discern an object's details at 200 yards, deer need to be within just 20 yards away. (They are better adapted to detecting motion.)
    Deer-car collisions peak with the fall breeding season, with males moving around to find receptive females."
    Read more here: http://www.newsobserver.com/2010/12...rs-why-do-they-freeze.html?rh=1#storylink=cpy
    Shutting off your headlights, and making noise should therefore avoid the 'freeze' reaction to the light, and the noise should make the deer react, however that means that your own eyes have to suddenly adjust to the lack of light as well, and also takes away brain processing power to react to the defensive driving actions of slowing and steering to avoid a collision. The 'freeze' reaction is helpful if the deer are on the side of the road. My experience in hitting deer (3x) is
    1) no reaction time available, deer jumped over a no-post curb right into the truck. Killed deer.
    2) braked and steered to avoid collision; deer continued on its path, unaffected by lights/horn and ran into the side of the truck. Deer survived.
    3) braked to avoid collision; deer continued to run across road, and was hit at low speed, rolling on the ground, and getting back up.
    At no time did the deer stare and dive into the light, in all 3 cases the deer was already in motion and continued its direction of travel.
    I've had lots of near misses. Usually one of the herd raises their head at the sound/light of the vehicle. Most continue grazing along the roadway, rather oblivious.
  18. Nov 9, 2014 at 6:20 PM
    #58
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    You're selfish Ding, and play unfairly blinding your opponent into indecision.
  19. Nov 9, 2014 at 7:39 PM
    #59
    monkeyface
    Colorado
    You're so cute, huggable, adorable and funny. But, I'll have to dissect.
    WTF are you talking about? Really? THIS you think is an important point? L-M-A-O. I guess it will impress some people here.
    Flicking the headlights off for two seconds is a big deal? Man, you must not have done much driving. Which is why I have questioned your overall driving skills. I'm not trying to demean you, but I think it's obvious you don't have a lot of driving skills or experience either onroad or offroad. Pretty much just a smartass.
    You haven't stated what you do when you see a deer at night, have you? That's two different things. You make the smartass comments, so huggable you little cutiepie.
    I love you man, but. Well, carry on, been an interesting discussion.
  20. Nov 9, 2014 at 7:56 PM
    #60
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Did you type that with the lights off? :D
