Defined Engineering EXT travel shackle
Discussion in 'Suspension' started by PLC721, May 15, 2012.
  1. May 15, 2012 at 12:39 PM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    before i start my rear shock hoops to fit my 12" 2.5's, what is everyones thoughts on doing the defined ext travel shackles while I'm at it. i wouldn't mind losing .5" of rear ride height either, they also will allow for more droop I'm assuming? what does everyone think? does anyone on here actually have them?
    Thanks,
    Patrick
  2. May 15, 2012 at 12:48 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'd run 'em if I were you. If nothing else they'll be stronger than stock.
  3. May 15, 2012 at 12:56 PM
    PLC721
    Patrick
    Chandler, Az
    and its greasable too which is convenient to make it a lasting product
  4. May 15, 2012 at 1:42 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    AMAES talked about them having a better fluid motion than stock too. I haven't seen them on any trucks other than the SUA kits.
  5. May 15, 2012 at 3:28 PM
    PLC721
    Patrick
    Chandler, Az
    hmm guess ill have to be first and write a review!
  6. May 15, 2012 at 3:51 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I thought this product has been out for a while.
    PM Defined to see his input on the benefits
  7. May 22, 2012 at 12:30 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
