Definitive Double Cab 4 Banger Thread
Discussion in '4 Cylinder' started by TailDrag, Jul 3, 2013.
  1. Dec 14, 2017 at 6:16 PM
    #61
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I have not seen any 2nd gen DCSB 2.7L that are 5 spd. I'm not sure that config was offered. I've been considering converting mine to a 5 spd. It will happen eventually.
    BassAckwards[QUOTED] likes this.
  2. Dec 14, 2017 at 6:49 PM
    #62
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yeah, everyone of them ive seen has been the 4 speed auto. I think there was someone on here though that said they had a five lug double cab with the 5spd..
  3. Dec 14, 2017 at 7:12 PM
    #63
    jowybyo
    Joe
    Baltimore, MD
    That's quite possible. Seems the 5-spd was more readily available on the 5 lug. I'd like to the the swap, but then I start to think if I'm going to swap the transmission and the engine ECU and engine wire harness, I might was well go ahead and swap the motor to the 6 cylinder (or LS swap if I really want to get fancy) at that point.
  4. Dec 14, 2017 at 7:28 PM
    #64
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Gearing between the manual and auto are different, so trying to compare gear changes between the two is like comparing apples to oranges. With the manual, 4.56 gears and 33s match stock revs and 4.88 gears and 35s match. 5.29 gears exist. Nitro and Yukon both make rear 5.29 gears. Yukon is the only one that makes front 5.29 gears for the 2nd gen.
  5. Dec 14, 2017 at 11:20 PM
    #65
    Silvatacoma
    Silvatacoma Well-Known Member
    Hawaii
    Here’s mines. 2012 2.7 auto prerunner.
    Wish it was 4x4....Wish it was V6....Wish it was 5spd....Ah, such is life !
  6. Dec 15, 2017 at 10:25 AM
    #66
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Pretty sure the salesman told me the 5sp wasnt avail in the DC when i bought mine.
    BassAckwards likes this.
  7. Dec 17, 2017 at 5:15 PM
    #67
    FredRey
    FredRey New Member
    2014 Tacoma DC SR Super White
    Here's mine
    2014 DC SR I4 AT
    265/70-17 3" lift IMAG0517~2.jpg
    Silvatacoma and BassAckwards like this.
  8. Dec 17, 2017 at 5:51 PM
    #68
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    Here's mine
    Picked her up yesterday
    Mitch76, 09 Redneck, Misfit and 2 others like this.
  9. Dec 17, 2017 at 8:50 PM
    #69
    Silvatacoma
    Hawaii
    Truck looks awesome! What’s the specs on the lift?
  10. Dec 17, 2017 at 8:55 PM
    #70
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    I test drove a 2016 access cab, 4cyl auto. It didn't have enough power to pull a greasy string out of a whores ass. I couldn't imagine how shitty it would be with the extra weight of a double cab.
  11. Dec 17, 2017 at 11:06 PM
    #71
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    Thanks for coming in here to talk crap. Mine does just fine, even with a lift and bigger tires. It’s not a rocket ship, but I don’t want it to be so I don’t care.
  12. Dec 17, 2017 at 11:46 PM
    #72
    easleycrawler
    Travis
    2014 RC Taco 4wd
    I ain't talking shit, especially about toyota's, I've had many Tacoma's. I just stated the obvious about the 3rd gen Tacoma's. Maybe it's the gearing, or the the new automatic. Either way, they are not as peppy as the 1st and 2nd gens.
    Tacotruck7[QUOTED] likes this.
  13. Dec 18, 2017 at 5:41 AM
    #73
    BassAckwards
    Good looking truck sir! Did you add the sport mirrors yourself?
    srdoublecab2.7 likes this.
  14. Dec 18, 2017 at 5:49 AM
    #74
    srdoublecab2.7
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    Ok so for all of you 2.7 guys
    How are the 265s and the little 4 banger?
    I'm about to get some scs f5 ( light weight ) and some falken at3w or even lighter the hankook all terrains
    What you guys think?
  15. Dec 18, 2017 at 5:51 AM
    #75
    BassAckwards
    I didnt notice much of a loss in power, and i have run e load 265/75/16s. I think if you get a lighter load rating, you wont have any problem at all running that size. Do you have the 5spd or the auto though? I have the 5spd in mine and i think that helps some. It might be a little more noticeable with the auto
  16. Dec 18, 2017 at 7:49 AM
    #76
    Tacotruck7
    SoCal
    I run 32’s at 255/75/17 load range C. Lost some mpg but power is fine. Don’t get a E rated heavy tire unless you’re off-road a lot.
  17. Dec 18, 2017 at 7:58 AM
    #77
    Silvatacoma
    Hawaii
    I went with some Toyo Open Country AT II’s P265/75/16 as i rarely leave the pavement. It looks like the higher load rated model but only weighs 41 lbs. I can tell a little bit of a difference coming from the stock 245’s but that’s only on long inclines on the highway.
  18. Dec 18, 2017 at 8:22 AM
    #78
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    4 bangers and v6 engines don't produce power, v8 engines will produce it, your looking at the wrong engines if want power
  19. Dec 18, 2017 at 8:50 AM
    #79
    easleycrawler
    Travis
    2014 RC Taco 4wd
    No shit.
  20. Dec 18, 2017 at 8:31 PM
    #80
    srdoublecab2.7
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    For those of you that are running lifts
    Anyone running old man emu springs? Trying to do like a 2/1 lift with some 5100s and springs
    Any ideas would be greatly appreciated!
