Defrost engages AC compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tremelune, Jul 26, 2009.
  1. Oct 15, 2013 at 11:08 AM
    airlandsea
    airlandsea New Member
    Syracuse, NY
    2013 Access Cab 2.7 5sp.
    The 4 cyl. in my 2000 Taco was just fine, this one seems to have less grunt. If I knew it would take such a hit from turning on AC I would have gone for the 4.0
  2. Oct 15, 2013 at 11:31 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The 4cyl in my '98 Taco was a ballsy beast. I don't recall the AC ever making it break a sweat.
    If I could only find that truck again.....
  3. Oct 15, 2013 at 4:16 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Not very well.
  4. Oct 15, 2013 at 5:24 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    I don't remember loaning you my keys... so how would you know how well it worked? I never had a problem with them defrosting.
  5. Oct 15, 2013 at 5:31 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You live in the land of almost no humidity so it's not really an issue there. It's more the defog that needs the a/c, not the defrost. I need it a lot on cooler mornings here.
  6. Oct 15, 2013 at 6:12 PM
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    If there is any dust on the windshield, the humid air causes fog on the wind shield. Here in Pennsylvania, I can't imagine not having AC running to defrost. It just doesn't work.
  7. Oct 15, 2013 at 6:36 PM
    BamaToy1997
    Bill
    Navarre, FL
    While the defrost still worked in the older vehicles, they were MUCH less efficient. I can defrost my front windshield almost immediately now. My 70 Mustang didn't have that option, and I remember having to wait for the engine to warm up before I could defrost. Sure you don't NEED the compressor to run, but the efficiency is MUCH better with the compressor on. especially in areas where the humidity is higher.
  8. Oct 15, 2013 at 6:58 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The AC helps with defogging, but for actually defrosting frost off the window AC doesn't do anything. If I have frost on my windows it is already 32F outside and the air is not dried by the AC since the evaporator is only around 35F.
    I set the heat to the center "floor" position and that gets plenty of hot air to the windshield which melts the frost just fine.
  9. Oct 15, 2013 at 8:04 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    Lived in PA for the 1st 33 years of my life, (when I owned those non AC vehicles) so I know about humidity.
    I KNOW that the AC helps dehumidify and defog, my point was cars did it for years without it, and it worked.
    SO those who want to blow non dehumidified air on their windshield should have the ability to do it... :cool:
  10. Oct 15, 2013 at 8:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Just do the mod
  11. Oct 15, 2013 at 8:40 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    I never said I wanted it... :D
  12. Oct 16, 2013 at 4:47 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Guess you never tried A/C to get rid of the moisture.
  13. Oct 16, 2013 at 4:48 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Buy a truck with out A/C
  14. Oct 16, 2013 at 5:03 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    If I am not mistaken don't the ac have a low temp compressor shut off? I don't know where the set point is but I don't think it runs very much when it is below 30 or so. The mod seems like a good idea.
  15. Oct 16, 2013 at 5:26 AM
    #35
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    I did the AC / Defrost disconnect mod and my windows clear just fine. In fact, I don't notice any difference in the amount of time it takes them to clear. The temperature and velocity of the air blowing on the windshield has a much more significant effect on the rate of evaporation than the dehumidification from the AC unit. I think Toyota does this to keep the compressors in good shape as much as to help with clearing humidity from the windshield.
    Anyway, just do the mod and if your window is a little more foggy than normal some days (for whatever reason) then just press the AC button and you will have the benifits of dehumidification when you want it (it still works).
  16. Oct 16, 2013 at 9:56 AM
    #36
    Brodie
    Brodie Gear Jammer
    Colorado
    Would a 1972 Blazer count?
  17. Oct 16, 2013 at 2:28 PM
    #37
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's frost it's on the outside! Scrap it off A/C will not melt ice.
  18. Oct 16, 2013 at 2:29 PM
    #38
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yeah or maybe a 62 Pontiac.
  19. Oct 16, 2013 at 4:11 PM
    #39
    Hbr01
    Hbr01 Well-Known Member
    Brian
    Jax, FL
    12 DBC 4x4
    The ac compressor only kicks on in the "blue" setting, once you hit a certain point on the temp knob the AC compressor kicks off. You can confirm this by the RPMs.
  20. Oct 16, 2013 at 4:16 PM
    #40
    worthywads
    wut? The rest of us in cold weather get frost inside too.
