defrost smells like stinky socks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jdog73, Nov 13, 2014.
  1. Nov 13, 2014 at 11:33 AM
    Jdog73
    Jdog73 [OP] Active Member
    Pocatello Idaho
    12 Tacoma SR5 L/B
    Why would my defrost smell like my 17 yr olds nasty socks? Only defrost nothing else?? Help. :mad:
  2. Nov 13, 2014 at 11:37 AM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    'Cause irt's a good place to stash used condoms.
  3. Nov 13, 2014 at 11:38 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    After the filter, check the vents under the winshield, maybe spray some mildew bathroom spray in there if the smell remains.
  4. Nov 13, 2014 at 11:43 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    In the future make sure to turn off your AC and defrost and let the condensation on your compressor dry up before shutting the truck down. It will help tons.
    In the meantime there are a few aerosol products that are used to spray into the intake vent while vehicle is running to remove the odor, GL
  5. Nov 13, 2014 at 12:46 PM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    I believe the cabin air filter was recently replaced so I don't think that's it.
  6. Nov 13, 2014 at 12:51 PM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    I do not know what your stink is but I bought a truck from a field for a friend and it had mice all on the ducts. I'm sure that's not your problem, but I used a cheese grater and grated some zest soap and put it on paper plates and let it bake in the sun with the windows up. That was 2 years ago and the guy still says is smells shower fresh.
  7. Nov 13, 2014 at 12:53 PM
    Idaholandho
    ^ guaranteed.
  8. Nov 13, 2014 at 1:38 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    +1, this should fix it
  9. Nov 13, 2014 at 1:54 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    does anyone have a source for a good charcoal cabin air filter element?
  10. Nov 13, 2014 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  11. Nov 13, 2014 at 9:48 PM
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    check for dead rodent in the system.. seriously, its happened and emits a horrible rotten moldy smell when the defrost is turned on.
  12. Nov 14, 2014 at 6:22 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    My thoughts are the AC condensent tube is blocked leaving moisture in the system leading to mold. I think the ac cycles when on defrost to dry out the air for more effective defrosting and the air blowing across the ac evaporator coils brings the smell with it.
