Defroster Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Red_03Taco, Mar 2, 2023.
  1. Mar 2, 2023 at 7:18 AM
    Red_03Taco
    Red_03Taco [OP] Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Hello all. So for the past few months my defroster has been having an ongoing issue, where it allows my driver side window to fog up constantly. It keeps the windshield and passenger-side window nice and clear, but I have to constantly wipe my driver side window with a towel to be able to see out of it. Its as if the left-most (if you're looking forward at the windshield from the driver's seat) defroster vent isn't emitting very much airflow (yet the left side of the windshield seems unaffected oddly enough. Any ideas on how to address this, as it's immensely annoying? I've considered getting an air nozzle on my air compressor and blowing out that vent, but wondered if blowing whatever may be in there deeper into the vent could create more problems than solutions. Has anyone experienced anything similar? Any help will be much appreciated. Thanks
    HondaGM likes this.
  2. Mar 2, 2023 at 7:23 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    You might have something in the vent? Try something like a weed blower on the interior side first. Open the hood and see if anything blows out? Maybe you have leaves or a critter nest in there?
    HondaGM likes this.
  3. Mar 2, 2023 at 7:26 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is there air flow with the A/C on? Maybe the hose is off to that side?
    HondaGM and Bivouac like this.
  4. Mar 2, 2023 at 8:10 AM
    Red_03Taco
    Jerad
    I will check that out after work today and report back. The truck is garaged 95% of the time, and is my DD, so I'm fairly doubtful of critters, but leaves aren't out of the question I suppose. I'm leaning more towards 20+ years of AZ dust being packed in there. My main concern is whether or not blowing that dust inward, from the cab towards wherever those vents lead, could damage or block other parts of the AC/heat ducting system. I might look at my Factory Service manual at the schematic breakdown of that system before committing to blowing whatever is in there back that way. Any idea whether or not I can actually break into that system from the engine bay side and blow out into my cab? It'd probably make a royal mess in there, but I could always vacuum that out afterwards. Was hoping to get some info from anyone else who'd experienced similar issues.
    HondaGM likes this.
  5. Mar 2, 2023 at 8:13 AM
    Red_03Taco
    Jerad
    The driver side AC vent (left of the steering wheel) does get airflow with the AC on, but I've never really put my hand over the dash to feel for cold air coming out of the upper dash/defroster vents. I'll check this out this afternoon too.
  6. Mar 2, 2023 at 8:14 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The vents don't go through to the engine bay at all. They "start" in the cowl below the windshield, go into the blower motor, and then out into the cab behind the dash, and under the seats (alongside the transmission hump).
    If the truck has been in the garage most of it's life, I would more likely suspect that one of the ducts has disconnected behind the dash.
  7. Mar 2, 2023 at 11:41 AM
    Red_03Taco
    Jerad
    I will definitely try to investigate that. If I remove the lower dash panel below the steering column, do you think I'll be able to see up there far enough to determine if that's the case? I'd like to not have to go too far into a dash removal to diagnose this issue if I don't have too. Despite this truck being garaged, it does still get used as a hunting & camping rig, and up here in Northern AZ we do get some heavy dust that could be blocking that vent too. You think the disconnected duct is a more likely culprit though? I figured since these trucks don't have cabin air filters the dust accumulation could be pretty serious up in there
  8. Mar 2, 2023 at 12:03 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    That removing the lower dash panel should allow you to see just fine!!
    Duct work tends to come apart.
    Rodents also like building nests as well.
  9. Mar 2, 2023 at 12:21 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I think just getting it opened up from the blower motor and giving things a clean out will lead you to whatever the issue may be.
