defroster problem on 2017 tacoma dbl cab SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captnbill, Feb 12, 2017.
  1. Feb 12, 2017 at 8:15 AM
    captnbill
    captnbill [OP] Member
    2017 tacoma double cab sr5
    With the temps in the low teens and snow and ice here in NH the defroster is not designed right. Both sides freeze up quickly and the top by the rear view mirror. Heat on as high as it can go and full defrost does not solve this issue. To hot in the cab to tolerate that temp too long. Anyone else have this issue. Love my truck but this just will not make me a returning customer.
    Bill
  2. Feb 12, 2017 at 8:50 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  3. Feb 12, 2017 at 8:56 AM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    No issue with mine and I live in Utah and had lots of of highs in the teens with plenty of snow. Windows clear fast and never had the mirror ice up.
  4. Feb 12, 2017 at 9:06 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Do you have the setting on fresh air or recirculate?
    Herniator likes this.
  5. Feb 12, 2017 at 9:27 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Make sure the setting is on fresh air and try using the AC. The AC will help dry the out the air in the vehicle.
    shakerhood likes this.
  6. Feb 12, 2017 at 9:48 AM
    Herniator
    Edmonton
    Also check if you have moisture in the vehicle. Like snow and ice on the floor matts. The frost comes from having high humidity.
  7. Feb 12, 2017 at 10:23 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Clean your windshield real good. I always notice a huge difference in de frosting/fogging with a clean windshield. my theory is that its less for the moisture to grab onto.
  8. Feb 12, 2017 at 2:35 PM
    captnbill
    No problem on the inside. All ice is on the outside. Defroster is on fresh air and full hot. It gets hot inside. The both sides of the windshield freeze up fast and the top center does the same
  9. Feb 12, 2017 at 2:38 PM
    captnbill
    Outside mirrors are heated. No problem whit them. I was saying the inside top windshield freezes up by the inside mirror.
  10. Feb 12, 2017 at 2:40 PM
    Glenn_R
    Glenn
    Use alcohol mix windshield wiper fluid.
  11. Feb 12, 2017 at 3:53 PM
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    2016 TRD Sport access cab 4x4 auto
    Black tube steps,mud flaps, fluid filmed tonneau cover,jbl speakers heated leather seat covers,bed mat,husky floor liners
    Do you have the auto climate control or manual? I live in NH. And have manual and it works great.
  12. Feb 13, 2017 at 12:01 AM
    captnbill
    manual and I have it on high and still cant defrost the ice on the sides or top of windshield
  13. Feb 13, 2017 at 12:10 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    My side windows frost up quick on my sport with heat in defrost mode. I usually just change it to head and feet and aim the circular outside vents at th windows. Mind you its also -20*c here
  14. Feb 13, 2017 at 12:29 AM
    captnbill
    the 2017 vents are fixed and can not be turned toward the windshield. You are talking about the side window vents? My other vents do move but cant be postioned toward the front
  15. Feb 13, 2017 at 1:47 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    I don't own a third gen so maybe irrelevant. My mirrors are constantly covered in condensation when I leave for work at 5am. I wipe those fuckers off so I can see and go about my day. Maybe you can try something like that?
  16. Feb 13, 2017 at 8:12 AM
    Broccoli
    Airdrie Alberta
    Oh didnt read the full post, sounded like your side windows. I have had no issue with windsheild frost except maybe a 1-2" strip at the top which does not affect my visibility.
  17. Feb 13, 2017 at 9:13 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Hmm, I live in NH and do not have this issue. Of course I have tracked plenty of snow into the truck from the awesome weather we have had. This is truck is awesome in these conditions!!
  18. Feb 13, 2017 at 9:22 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    I applied some aquapel to my windows since I HATE using wipers. seems to have made ice scraping easier. But in any vehicle I've owned. Ice buildup from frost overnight takes some time to defrost.
  19. Feb 13, 2017 at 9:22 AM
    Herniator
    Edmonton
    I live in Canada and have no problems clearing my windshield. Maybe op has stuff on his dash blocking airflow or something.
  20. Feb 13, 2017 at 9:29 AM
    JMaddy13
    JMaddy13 Well-Known Member
    Jeff
    Denver, Colorado
    2016 TRDOR Inferno
    RTT on a rusty rack I made
    My windshield clears up fine, but the driver and passenger windows always fog up with the defroster on. The problem is not affected by the amount of moisture in the vehicle, same if dry or wet.
    Quick workaround is to point the side vents at the window and the small bit of air that leaks out clears them up!
