Defroster screeching noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dasdorian, Jul 28, 2017.
  1. Jul 28, 2017 at 11:53 AM
    dasdorian
    dasdorian [OP] New Member
    David
    2006 Tacoma std cab 2 wh 4 cyl
    I have a 2006 Tacoma (std cab, 2 wh, 4 cyl). Recently, when I turned on the A/c there was a screeching noise and the a/c system blew warm air. I was told the compressor needed replacing but due to the cost I decided I would drive with the windows open.
    Today, there was a heavy rain and the windows fogged up. I diverted the air to the windshield and lo and behold, I heard the same screeching noise that occurred when I turned on the a/c. To be clear: The a/c was OFF; I had the fan on and the air blowing into the cab; I then diverted the air to the windshield and the screeching started; I diverted back to the cab and the screeching stopped. I did this several times to be sure.
    So the issue seems to be: what is the common element(s) between the a/c and the defroster? There must be some common part of the HVAC system. It can't be the a/c compressor because the compressor is not involved with defrosting the windshield. Is it the a/c clutch? I don't know, does anyone out there know?
    Any help will be greatly appreciated.
  2. Jul 28, 2017 at 11:56 AM
    la0d0g
    running for the hills
    For crawling not hauling
    The AC is used everytime you use the defroster.
  3. Jul 28, 2017 at 11:57 AM
    la0d0g
    To ensure everything stays nice and used during the winter months.
  4. Jul 30, 2017 at 10:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Go to the fuse panel under the hood and remove the MG CLT Relay. This will stop the clutch on the compressor from engaging and the screeching will stop.
  5. Jul 31, 2017 at 3:35 AM
    dasdorian
    David
    Jimmyh: Thank you very much. I feel foolish that I didn't think of this because when my a/c stopped working I went to the fuse box to make sure the MG CLT relay fuse was working properly (swapped fuse with one that I know was working).
    D
  6. Aug 12, 2018 at 4:01 AM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    and did this fix your AC problem as well? just curious... or just the whining?
    I too am experiencing that whine on defrost as well as AC.
  7. Aug 12, 2018 at 7:22 AM
    SixtyDashOne
    Collegeville, PA
    i just went and replaced the relay and no dice
  8. Aug 12, 2018 at 7:24 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    it is your blower motor
