DEI DBALL2 Remote Start Install using OEM fob - 2017 Tacoma Push to Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gpb, Dec 22, 2016.
  1. Jun 23, 2018 at 9:54 AM
    #161
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    On my 2016 sport i installed Fortin EVO-ALL and get the Fortin THAR-ONE-TOY6 -Wiring kit, its plug and play , if thats the one for your truck, spend the money it saves HOURS !
    its not to bad to do but the instruction suck , read it a few times and look for a youtube vid,
    i don't use it a lot but it works, had it in for only 4 months or so.
    edit fixed THAR-ONE-TOY7 to THAR-ONE-TOY6
  2. Jul 2, 2018 at 4:09 PM
    #162
    Sam2day88
    Sam2day88 Member
    Scott
    2018 Tacoma
    So the EVO-ALL comes with the THAR-ONE-TOY7 or was that extra? Was it that easy to install?
  3. Jul 2, 2018 at 8:14 PM
    #163
    jerkwithkeyboard
    Had to get them separate / ebay about $75 for the plug , at the time i had a hard time getting the wire set ? sold out maybe? don't know if you can get them as a set.
    I also had to get the Flash link updater to flash my truck info on to it,and change anything else i wanted to, but it was cheeper for me as i also was putting one on my wife's car.
    it was easier to watch a youtube video and then read the sheet. / a few clips and a few screws and snap off a panel or two and your there.
    took longer to set every thing up than to plug it in, plus if i want to add anything i can just re-flash it to suit. just get the right plug for your truck,
    also i used
    Fortin THAR-TOY6 Toyota / Lexus T Harness for Select Push Start Vehicles
    not 7
    2016-push-to-start
    Sam2day88[QUOTED] likes this.
  4. Jul 2, 2018 at 9:36 PM
    #164
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    I was about to say the same thing, it is the THAR-TOY6 not the 7.81A69CCB-AC66-460C-ABFA-BF41808208B1.jpg
  5. Jan 10, 2019 at 11:01 AM
    #165
    Jayro
    Jayro Well-Known Member
    Los Angeles
    2019 TRD Pro and 2019 TRD Off-road
    Nice work!
  6. Nov 22, 2019 at 11:28 AM
    #166
    gene158
    gene158 New Member
    Gene
    2018 Tacoma TRD sport
    Hey guys so I have a 2018 dcsb trd sport. I bought it used last year but it was basically new with only a couple thousand miles. Anyway, it came with a remote starter already installed. I have no idea which one is installed but there is separate key fob that came with my truck. I like the OEM smart key and the last thing I wanna do is carry around an extra key fob. Do you think it's likely that the unit I have can be programmed to work with the OEM key fob?
  7. Nov 22, 2019 at 4:26 PM
    #167
    TacoTruck808
    First Off, Welcome to TW!
    There are different brands of remote start systems for our trucks. What may help to answer your question is if you take a picture of the remote start control module or at the very least, the remote you are referring to. It could be a stand alone system with a long range remote or a D-Ball or Fortin with added RF remote capabilities.
  8. Nov 29, 2019 at 7:28 PM
    #168
    gene158
    gene158 New Member
    Gene
    So I checked and the system installed in my truck is a “blade-al.” I checked the website and it’s a little confusing. It seems like there is a way to program the oem key fob to operate the remote start, I just don’t understand how to do that.
    https://www.idatalink.com/product/product/product_id/4
  9. Feb 13, 2020 at 10:11 AM
    #169
    Peterbuilt
    Peterbuilt Member
    Pete
    Sudbury, Ontario, Canada
    ‘19 Voodoo TRD Pro Tacoma
    Hey, just installed my KBVoodoo starter and having an amber light on the starter when trying to program it, instead of a red light.
    Any help would be appreciated.
    *update*
    I went to town and got a local remote starter shop to reprogram the DBALL2 and now I only get a solid red light, once the ignition is on. I’d doesn’t go green at all.
    Thanks in advance
  10. Feb 16, 2020 at 7:33 AM
    #170
    Peterbuilt
    Peterbuilt Member
    Pete
    bump please help
  11. May 24, 2021 at 2:04 PM
    #171
    Marvet85
    Marvet85 Well-Known Member
    2021 Tacoma TRD Off-road
    Just starting.
    Can this cause any errors?
  12. Dec 23, 2022 at 3:40 AM
    #172
    Library unicorn
    Library unicorn New Member
    https://youtu.be/1noZRFnr-iE
    Had this exact kit installed. Keeps the engine running even if doors open. I'm also able to start it with doors open which was a nice surprise.
  13. Feb 15, 2025 at 3:12 PM
    #173
    millcho
    millcho Active Member
    Chicago burbs
    23 TRD OFF ROAD
    Hello, resurrecting an old thread with new questions, I'm about to tackle DIY Compustar 2way install on 23 Tacoma 4x4OR and the diagram shows PTS Gray at pin 1, I was wondering if somebody knows an alternative location for that wire, can it still be found at Smart KEY ECU? TIAupload_2025-2-15_17-3-40.png
