DEI DBALL2 Remote Start Install using OEM fob - 2017 Tacoma Push to Start
Discussion in '3rd Gen. Tacomas (2016+)' started by gpb, Dec 22, 2016.
  1. Jan 3, 2017 at 4:22 AM
    #101
    gpb
    gpb [OP] Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    That's got to be fake. *Four* days of sunshine? In a row?
  2. Jan 3, 2017 at 6:00 AM
    #102
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    What is the Smart Start module that can be attached to the DBALL
  3. Jan 3, 2017 at 6:20 AM
    #103
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
  4. Jan 3, 2017 at 6:26 AM
    #104
    gpb
    Atlanta
    VangaSTL likes this.
  5. Jan 3, 2017 at 6:29 AM
    #105
    BadRobot62
    BadRobot62 Well-Known Member
    David
    2017 Tacoma Sport 4x4
    Level kit,
    Did you cut the unused connectors from the unit before wrapping them up.
  6. Jan 3, 2017 at 6:34 AM
    #106
    gpb
    Atlanta
    On the DBALL2 I just folded the unused wires over within the braid and left them be. There was enough insulation extending over the cores that I didn't do anything else. As for the additional connectors I just left them off the unit entirely.
    As for the SmartStart with it's hydra-like wiring, I just folded the unused connectors down and slid the braided sleeve over the bundle. Same for the octopus-like mass of connectors at the other end of the four-pin to four-pin cable, I folded over the parts I didn't need so they were covered by the braid.
  7. Jan 3, 2017 at 10:27 AM
    #107
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Nope that is for real - sunny in WA state. Of course we get sun here in winter, but probably get shite for sun in summer ha ha
    gpb [OP] likes this.
  8. Jan 17, 2017 at 1:10 AM
    #108
    GotRice?
    GotRice? Well-Known Member
    Edward
    Edmonton AB
    '16 White Tacoma LTD
  9. Jan 17, 2017 at 2:42 AM
    #109
    mthopton
    mthopton Well-Known Member
    '16 TRD DCSB 4x4
    PJ, thank you for this great post. It made the install a breeze - especially for someone that typically has to fumble through auto wiring! Your charts were great and very easy to follow.
  10. Jan 17, 2017 at 4:36 AM
    #110
    gpb
    Atlanta
  11. Jan 18, 2017 at 5:57 AM
    #111
    PJnc284
    Garner, NC
    Glad it helped. I spent weeks putting it together. :rofl:
    mthopton and gpb [OP] like this.
  12. Jan 18, 2017 at 6:00 AM
    #112
    gpb
    Atlanta
  13. Jan 18, 2017 at 8:14 AM
    #113
    mthopton
    '16 TRD DCSB 4x4
    Now if I can convince you to put together the same chart for a 2016 Nissan Frontier.... I'd be a superhero to my Wife!
  14. Jan 18, 2017 at 8:22 AM
    #114
    PJnc284
    Garner, NC
    Tell her to go buy a tacoma. :p The frontier doesn't look like it's remote start ready so it's likely to be a giant pain in the rear and require a separate alarm/remote start module.
  15. Jan 18, 2017 at 8:35 AM
    #115
    gpb
    Atlanta
    Here's what DEI says for the 2016 Frontier:
    https://www.directechs.com/VehicleCompatibility.aspx?p=-1&v=10501&ps=1&s=0&c=0
    The image @PJnc284 posted is from the DBALL2 Install Guide on that page; I'd suggest opening it and reading through it to see if it gives you a sense of how to proceed. I suspect you'll need the 4X10 remote start module, but haven't researched how its wiring interacts with the DBALL2's wiring.
  16. Jan 22, 2017 at 7:53 AM
    #116
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    @gpb I thought you had done a alternate termination on the big 12VDC wire on the ECU? Instead of stripping and soldering you removed the pin and connected another way. I can't find that info, maybe it was someone else. Thanks again for the great write up.
  17. Jan 22, 2017 at 8:51 AM
    #117
    gpb
    Atlanta
    I did but didn't focus on that in the write up. Pretty simple really, I pulled the plug out of the ECU then using a tiny screwdriver I released the catch holding the metal terminal inside the white plastic plug. Do so from the business end, you'll see the second opening that gives access. Metal terminal then pulls out the back and I soldered to the crimp. Make sure the tab/catch is how it's supposed to be and reinsert into white plug until it clicks in. Then plug it back in.
    Obviously do this with the battery disconnected.
  18. Jan 22, 2017 at 12:48 PM
    #118
    Glenn_R
    Glenn
    That was it, thanks!!
  19. Feb 4, 2017 at 12:22 PM
    #119
    taco33417
    taco33417 Member
    VA
    I've installed mine but now realize that I did not install an inline fuse on the 12V. Do I need one? I didn't see any fuse mentioned on any of the threads or I've missed it. Any thoughts?
  20. Feb 4, 2017 at 12:59 PM
    #120
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I know there's delay in the actual ignition sequence when you're using Apple Watch, what if I just use my iPhone, is it any quicker?
