Delay Before Engine will Start Manual Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baleklocoon, Aug 10, 2019.
  1. Aug 10, 2019 at 6:46 PM
    Baleklocoon
    Baleklocoon [OP] Well-Known Member
    Texas (DFW)
    2019 Tacoma TRD Off-road MT
    I just bought a new 2019 TRD Off-road with the manual transmission. Not sure if it being a manual has anything to do with my issue but I figured I would mention it in case. I've started the engine about 10 times since I bought it this morning, and more than half the times this is what happened:
    Engine will not start when I turn the key all the way clockwise. Check Charging Station message is displayed. If I wait until the computer boots and I hear the radio start playing and try again after I hear the radio, the engine starts no problem. Any idea what is going on here? It doesn't happen every time, but at least half the time. It didn't do it when I cranked the engine and left the dealership or I would have asked them. But I made several stops on my 450 mile drive home and at least half the time this happened when I cranked the engine after stopping. It isn't an unbearable issue because it always starts after waiting 5-10 seconds, but it could be a safety issue if something caused me to stall out and I need to start the engine immediately.
    I really can't imagine what the radio has to do with it, maybe a coincidence, but every time this has happened I have tried turning the key again before the radio turns on and it doesn't work. If I turn the key immediately after I hear the radio, engine starts right away.
  2. Aug 10, 2019 at 7:08 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Kinda sounds like an issue with the immobilizer to me.
    Or you may not have the clutch pressed to the floor fully to make it start.
    Shellshock, 9th and hiPSI like this.
  3. Aug 10, 2019 at 7:10 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    maybe like stated before...you are not pushing the clutch all the way in.
    mikey1d and shakerhood like this.
  4. Aug 10, 2019 at 7:11 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    ^funny they make you have the pedal all the way to the floor when the clutch engages at the top, eh?
    Burro09, SpensirG and e6400ultra like this.
  5. Aug 10, 2019 at 7:13 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    User error lol. No depressing the clutch fully before trying to start.
  6. Aug 10, 2019 at 7:13 PM
    9th
    Smitty
    Tropic of Cancer
    Yes...the clutch must be on the floor
  7. Aug 10, 2019 at 7:39 PM
    Baleklocoon
    Texas (DFW)
    Thanks for the quick replies. I am not new to manual transmissions. The first thing I did when it didn't start is double checked the clutch was pressed to the floor and tried again immediately, to no avail. When I tried again after the radio turned on, it started no problem.
  8. Aug 10, 2019 at 8:25 PM
    AKGSD
    Joe
    Alaska
    The warning message you’re getting is odd, i’ve not seen that.
  9. Aug 10, 2019 at 8:27 PM
    Baleklocoon
    Texas (DFW)
    Thinking about the immobilizer issue 513Mugsy mentioned, I wonder if it could have been caused by me having both keys present since I was on my way home from the dealership. Maybe having 2 RFID's or whatever security device is in the keys confused the system?
  10. Aug 10, 2019 at 8:51 PM
    AKGSD
    Joe
    Alaska
    Nah, i’ve had my second key in the glovebox on my manual trans one for a month now, no issues. Pretty sure on the old style keys you get with the manual it only detects the key when its actually in the ignition.
    MOC221_ likes this.
  11. Aug 10, 2019 at 8:55 PM
    Baleklocoon
    Texas (DFW)
    My extra key was in my pocket, so a little closer to the ignition than inside the glove box. But yeah I'm sure you're right. Just throwing it out there. If it keeps happening I guess I'll take it to the dealership eventually. I doubt they will know though if nobody here does.
  12. Aug 10, 2019 at 9:02 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Have you tried throwing it in N and starting with the clutch start cancle to see if you get the same result?
    shakerhood likes this.
  13. Aug 10, 2019 at 9:09 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Definitely not normal. I can hop right in and crank the engine over, no delay at all.
    Junkhead likes this.
  14. Aug 11, 2019 at 4:17 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    My husky mats keep me from starting some times. I have to push fairly hard on the clutch to get that switch engaged.
    su.b.rat likes this.
  15. Aug 11, 2019 at 5:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I cut a small section out of the mat to allow the clutch to go all the way down.
    su.b.rat and Bleep100 like this.
  16. Aug 11, 2019 at 6:04 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Only read half your post (sorry TL: DR)... It sounds to me like your clutch pedal isn't depressed all the way. Check it and see if when the clutch is depressed it is activating the switch. I taped a felt pad (the one you put under furniture legs to prevent scratching the floor) on mine to add an exta 1/8 inch and now I only have to depress the clutch aboit 90 percent before it starts.
  17. Aug 11, 2019 at 6:34 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    That warning is a normal message I've seen in multiple trucks. Anytime it has the key all the way turned but the truck is not started. Not sure what it's all about but I figure it's just a message to remind you that you're using the battery without the motor running. It's a non issue. As far as OPs issue, I've got nothing, other than to check the battery voltage.
  18. Aug 11, 2019 at 6:45 AM
    NevadaNick
    NevadaNick Well-Known Member
    2017 Access Cab 4wd 4cyl MT
    It has become a habit for me to use the clutch cancel button. When the seating position is comfortable its easier than pushing the clutch all the way.
  19. Aug 11, 2019 at 7:05 AM
    Tacowin1013
    Excuse me for being ignorant on this, but does that use the alternator to start? Meaning more wear and tear
  20. Aug 11, 2019 at 7:07 AM
    AKGSD
    Joe
    Alaska
    ^ nah brah
    Clutch start cancel removes the requirement for the clutch pedal to be depressed for the engine to crank over using the starter. In the manual, Toyota actually recommends you do this to get going on steep inclines. I’ve tried it, doesn’t work well. Why they gave the automatics brake-hold assist on hills but not the stick-shifts, i have no idea
