Delay in 4wd disengage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by m5allen, Nov 13, 2022.
  1. Nov 14, 2022 at 9:06 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You don’t push at all from 2H-4H and vice versa. Only need to push before switching between 4H-4L and vice versa. That’s why it only says “push” on half the dial dude.
  2. Nov 14, 2022 at 9:32 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    OP, this video is worth a 20 minute watch to understand the mechanics of the Toyota part-time 4x4 system that we have. I think the ADD actuator is the part that requires all the tension to be removed. That shift fork motor can't overcome the forces of a loaded axle.
    MOC221_ and m5allen[QUOTED][OP] like this.
  3. Nov 14, 2022 at 11:52 AM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    In addition, to take load off of gears snd drivetrain, backing jp a short distance helps.
    That's an Old School Four Wheel Drive technique.
  4. Nov 14, 2022 at 7:38 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    OP it doesn't matter how you actuate the switch. You can do it harshly or gently, no matter. If you turn the headlights on gently it's no easier on the system. The same is true of the 4wd switch. It's a simple electric switch.
    If you are switching it back and forth between 2wd and 4wd you are probably just confusing the system. Switch it to the mode you want and try to unload the drivetrain to allow the solenoid to operate. Maybe shift to neutral and let off the brakes. Try Park. Try reverse. Quit fiddling with the switch.
    CG256 and shakerhood like this.
  5. Nov 14, 2022 at 8:00 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I guess you'd have to define the delay length. I've had a little trouble getting into 4WD, but never out. I find as long as I'm not on the gas it'll move pretty seamlessly. It seems to take longer when not moving, but that's understandable.
  6. Nov 15, 2022 at 4:28 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    There’s the issue or non issue. Must be moving to EASILY switch it back .
