Delete EGR?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Aug 21, 2019.
  1. Aug 21, 2019 at 1:46 PM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Considering my truck is so old and emissions is no longer a problem I was wondering if anyone has had success deleting the EGR system on a 2.7 with any success. Reason I ask is mine is acting up... I imagine it would be tricky to get around the insufficient EGR flow code....
  2. Aug 21, 2019 at 3:24 PM
    1997tacomav6
    Denver
    Why is emissions not an issue? I have a 1997 and it will not pass emissions if I remove my EGR.
    There have been some people that have removed the EGR.
    If I remember you have to install a resistor on one of the EGR wires to trick the ECU that it is there
    or you will get a check engine light
    Rachelsdaddy[OP] likes this.
  3. Aug 21, 2019 at 5:03 PM
    Rachelsdaddy
    Southern NH
    Because I live in NH and anything 20yrs old doesn’t require a computer check anymore.
    1997tacomav6 likes this.
