Delete..or is it cleanup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caribe makaira, Nov 17, 2011.
  1. Nov 17, 2011 at 9:11 PM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    05 PreRunner TRD Offroad
  2. Nov 17, 2011 at 9:47 PM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    Just tried it...no luck on the #1 pin that you are pointing to...but it works perfectly on either slot to the right of your arrows. Turns off with the ignition to since it is the relay slot for the seat heater and air pump heater
    Now everything can be put in one box!
    Does the line need an inline fuse or is it protected elsewhere in the fuse box?
  3. Nov 17, 2011 at 9:52 PM
    caribe makaira
  4. Nov 17, 2011 at 10:00 PM
    caribe makaira
  5. Nov 17, 2011 at 10:03 PM
    munkeeboi
    Burbank
    Yes, this is much better than the rush/temp fix
    I circled the 2 - #2 slots that work in green
  6. Nov 17, 2011 at 10:55 PM
    munkeeboi
    Burbank
    I have no idea...but it works perfectly as I described to you. All the 3 relay ports are oriented the same way, where #1 is in the lower left.
    Bent #1 tab of fog relay, redirected to slot #2 of seat heater relay connection.
