Delete
Discussion in 'Buy / Sell / Trade' started by ClayCrusher, Jan 31, 2014.
  1. Feb 15, 2014 at 7:33 AM
    #41
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    May want to reword your first post. Do you really get 3 ropes for $60? Meaning $20 each or 3 ropes at $60 each.
  2. Feb 15, 2014 at 2:54 PM
    #42
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Seems pretty clear that it is $60 per rope. The average person can't even buy this rope (without loops) for less that $5 a foot.
    Kinetic recovery ropes are so expensive. These are a great deal.
    Op I would consider changing the title to: Kinetic recovery ropes.
  3. Feb 18, 2014 at 8:18 PM
    #43
    ClayCrusher
    ClayCrusher [OP] Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
    Back up to the top. I started working with nylon braid as well. This stuff stretches 85% more than the tow ropes! I'll have pictures up tomorrow. Basically, these can be added to the end of a tow rope to aid in recovery!
  4. Feb 19, 2014 at 4:58 AM
    #44
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Hmm Interesting!
  5. Feb 19, 2014 at 3:32 PM
    #45
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Got mine yesterday, nice lookin' rope. Thanks.
  6. Feb 20, 2014 at 6:49 AM
    #46
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    What's the pros and con on rope versus strap?
  7. Feb 20, 2014 at 7:15 AM
    #47
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    It really depends on what type of rope we're talking about. Generally speaking, people assume all rope is the same. Rope can actually consist of either double or single braid, polyester, dyneema, or vectran core. A double braid vectran core is going to have the most strength and little stretch, whereas a line made of polyester in the same diameter is going to have significant stretch but less strength. These tow ropes are made of the middle material, dyneema. They are advantageous because at 1/2 or 7/16 inch, they are EXTREMELY lightweight and can hold 21k anf 16k lbs respectively. They are easy to pack, easy to coil, can be run through snatch blocks, and can be piggybacked onto each other with relative ease. The downside to these ropes is that they are not kinetic. However, if you want a kinetic rope, I can make you a nylon braided extension and that will help with that. For example, you order a 20' tow tope and a 10' nylon extension--that gives you 30' of recovery rope and it has the same properties of a kinetic recovery rope.
    The other plus is the price. This rope is NOT cheap by any means. I'm running a great deal for forum guys while supplies still last.
    Straps on the other hand are all nylon/polyester so they are not strong for their size to strength ratio. You need a lot of strap to do the same job--so you end up with a lot of heavy strap to carry around to do the same job. Also, if you've ever worked in sand or mud, straps never seem to come clean. These ropes can be soaked in water and still wont weigh what a strap that's dry weighs.
  8. Feb 20, 2014 at 7:17 AM
    #48
    Taco Guy11
    Joe
    Western Maryland
    I need something for recovery an looking in to what's my best options before making a purchase
  9. Feb 20, 2014 at 7:29 AM
    #49
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Well these are all used for recovery.... a true "recovery rope" is going to stretch a lot so you can get a running start. That's best for a REALLY stuck vehicle in mud where straight pulling isnt working. These ropes can be used for just about any recovery. I am comfortable shock loading these no problem. You just won't get "help" like a kinetic rope will give you unless you add a nylon braided portion to it. If you're in the area any time, we can meet up and you can test out the different ropes! Just let me know.
  10. Feb 20, 2014 at 7:33 AM
    #50
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I wouldn't necessarily say there are pros and cons, however, different "tools" or ropes depending on different situations :crapstorm: I have a tow rope (hooks at either ends), ARB strap and just got my Bubba Rope.
  11. Feb 20, 2014 at 8:20 PM
    #51
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Here's one I made today! This is part of the new size and color offering.
    That's a 20' Blue 7/16 with reinforced Blue/black loops, and a soft shackle (extra).
  12. Feb 22, 2014 at 5:38 PM
    #52
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    New stock! Check the first post!
  13. Feb 22, 2014 at 5:45 PM
    #53
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    I have several in stock to ship out ASAP.
    (2) - 30' 1/2" BLUE with reinforced blue/black loops. @$142 shipped each
    (1) - 20' 1/2" RED/WHITE with reinforced yellow/red loops @$115 shipped
    (1) - 20' 7/16" BLUE with reinforced blue/black loops @@75 shipped
    (1) - 20' 7/16" GREEN with reinforced yellow/green @75 shipped
    I can still make custom ropes in 7/16" at any length or color.
  14. Feb 24, 2014 at 10:55 AM
    #54
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Still available!
  15. Feb 26, 2014 at 10:33 AM
    #55
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I forgot to sub this and lost it in my bookmarks. Now...i'm subbing for sure. Excellent looking product.
  16. Feb 26, 2014 at 12:58 PM
    #56
    60driver
    60driver Well-Known Member
    Sean
    CT
    10 DC TRD Sport 4x4 Tim Mica
    Illum 4x4 switch, 20" LED bar in lower grill, LED in scoop, aux fuse box, avid light bar and 'sliders'
    Got mine today, looks great. Thanks for the fast shipping and replies!
  17. Feb 26, 2014 at 12:58 PM
    #57
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Glad you got it quickly! Things got a little crazy over on this end, but eveything went out as planned. Keep the orders coming guys!
  18. Feb 28, 2014 at 7:37 AM
    #58
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
  19. Mar 2, 2014 at 4:47 PM
    #59
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Get your ropes fast! They're going quickly!
  20. Mar 6, 2014 at 8:06 AM
    #60
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
